    Two moves generated from single G1 command
    • gnydickundefined
      gnydick
      What would make the machine go whOOoo whOOoo (a 2 segment straight line with accel and deccel for each one) if it's at 0,0 and you give it G1 X290 Y290?
      stepping is 16 with interpolation
        Too low a Z jerk value and mesh compensation active can cause stuttering that might fit the description.
        gnydickundefined 1 Reply Last reply Reply Quote 1
        • gnydickundefined
          gnydick @Phaedrux
          @Phaedrux that sounds right!
