    retraction, bed dimensions and z height help please
    123
    • A Former User
      A Former User last edited by
      first thanks to all that replied to my previous requests for help. Hardware nema 17 motors, micro switch end stops from original tronxy x1 no probing of any kind. Problem 1, manual leveling of bed is good but at start of print z axis raises up a little causing no bed adhesion. Problem 2, at end of print the filament is retracted too far. Problem 3, when print leveling test the print does not go to the ends of the bed. To print the test I have to manually raise the bed after start of print. With the old Melzi board and Repetier firmware I had no problems. Searched everywhere and everything has probing .
      Phaedrux 3 Replies Last reply Reply Quote 0
        https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
        Please post your config.g, your homing files, and your slicer start and end gcode so we can see what the printer is actually doing.
        A Former User 1 Reply Last reply Reply Quote 0
        • A Former User
          This post is deleted!
          • A Former User
            A Former User @Phaedrux last edited by
            @Phaedrux Found them. homeall.g config.g homex.g homey.g homez.g ; Default start code
            G28 ; Home extruder
            G1 Z15 F{Z_TRAVEL_SPEED}
            M107 ; Turn off fan
            G90 ; Absolute positioning
            M82 ; Extruder in absolute mode
            {IF_BED}M190 S{BED}
            ; Activate all used extruder
            {IF_EXT0}M104 T0 S{TEMP0}
            G92 E0; Reset extruder position
            ; Wait for all used extruders to reach temperature
            {IF_EXT0}M109 T0 S{TEMP0}
            ; Default end code
            ;G1 X0 Y0 Z130 ; Get extruder out of way. Uncomment to use!
            M107 ; Turn off fan
            ; Disable all extruder
            G91 ; Relative positioning
            {IF_EXT0}T0
            {IF_EXT0}G1 E-1 ; Reduce filament pressure
            M104 T0 S0
            G92 E0 ; Reset extruder position
            M140 S0 ; Disable heated bed
            M84 ; Turn steppers off
              Phaedrux Moderator @Guest last edited by
              @Newbie said in retraction, bed dimensions and z height help please:
              It looks like you have your slicer configured to use absolute extrusion moves.
              But then in the end gcode you have an extruder move that appears to be formatted as a relative extrusion move.
              Those two things combined mean that instead of retracting 1mm of filament at the end of the print, it's telling it to retract all of the filament printed during the entire print.
              I would suggest changing your slicer to use relative extrusion. Then in your start gcode change M82 to M83.
                How sure are you that your Z steps per mm is 2560?
                M92 X100.00 Y100.00 Z2560.00 E80.00 ; set steps per mm
                If you jog the z axis 10mm, does it actually move 10mm?
                  Phaedrux Moderator @Guest last edited by Phaedrux
                  Are you sure you've entered the correct size of your bed?
                  M208 X295 Y300 Z285 S0 ; set axis maxima
                  Are you also sure that the steps per mm for X and Y are correct? If you jog 10mm, does it actually move 10mm?
                  • A Former User
                    Really appreciate all your help. I managed to get z axis behaving good. Homes good and is not 2mm or more above at the start. All axis move to the limits. And now I have to work on the retraction. All I have to go by are the eeprom settings thtat were originally for the tronxy x1 with melzi board and repetier firmware. Retraction settings for the end of print (I take it) are from the repetier host. I'll have to experiment with that.
                    • A Former User
                      @Phaedrux Really appreciate all your help. I managed to get z axis behaving good. Homes good and is not 2mm or more above at the start. All axis move to the limits. And now I have to work on the retraction. All I have to go by are the eeprom settings thtat were originally for the tronxy x1 with melzi board and repetier firmware. Retraction settings for the end of print (I take it) are from the repetier host. I'll have to experiment with that.
                      • A Former User
                        @Phaedrux Updated to version 3 and now everything is screwed up again. I give up, I'm going to try the mks gen v1.4.
                          Oh no, why did you do that? There's quite a few changes to the config that need to happen for that. You can still go back to 2.05.
                          • A Former User
                            Maybe later but I fixed the original board so I will be using it for now to complete a couple of hobby projects. Again, thanks for all your help.
