    Error: short-to-ground and error: over temperature.
    • toddwagner
      toddwagner last edited by
      Just finished building and wiring up my printer. I am using duet 2 and duex 5. I get this error when I have the duex connected, but no error when it is disconnected. Any idea?
      toddwagner 1 Reply Last reply Reply Quote 0
      • toddwagner
        toddwagner @toddwagner last edited by
        I have checked all fuses on both boards, the voltages at the duet input and the duet input, both read 24.2 volts. Triple checked the wiring. Still the same issue. Does anyone have anything I might want to look into?
        Printer: railcore 300zlt
        • droftarts
          droftarts administrators @toddwagner last edited by
          @toddwagner check VIN and GND aren’t swapped on Duex, they are the other way around from the Duet. See https://duet3d.dozuki.com/Wiki/Duex_wiring_diagrams#Section_Warnings_and_Cautions and https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
          If that doesn’t help, disconnect everything, then reconnect and test one connection at a time.
          • toddwagner
            toddwagner @droftarts last edited by
            @droftarts will do. I disconnected everything from the duex except for the power in and the ribbon connector to the duet. Still the same reading. The only time it goes away is if I disconnect the duex from the duet.
            A Former User 1 Reply Last reply Reply Quote 0
            • A Former User
              A Former User @toddwagner last edited by
              @toddwagner said in Error: short-to-ground and error: over temperature.:
              Sounds to me like one or more of the stepper drivers on the Duex is preventing the SPI bus from working dragging down the whole lot on the Duet and the Duex when connected. Beyond checking if any of the stepper driver chips on the Duex board get warmer than say those on the Duet it might not be easy to say which one.
              On the other hand maybe the Duet guys have another idea
                Agreed, the DueX is pulling the SPI_MISO line high or is suppressing the SPI_SCLK line. This could be caused by the pins on the back of the DueX shorting against something conductive under the DueX, or a faulty ribbon cable, or a faulty DueX, or a piece of metal swarf on top of the DueX.
                If you connect the ribbon cable to the Duet but not to the DueX, do you still get the messages?
