    Is there a basic guide to set the duet up as a CNC
    CNC
    512
    • Asdasd1234
      Asdasd1234 last edited by Asdasd1234
      Is there a basic guide anywhere I'm missing for setting the duet3hc up as a cnc board.
      I.e which commands I'd need to add to the config and stuff to enable work-coordinate systems?
      I've had a look through the gcode documentation but I'm lost.
      My machine is now fully built, the board is wired up and I've sorted out the basics (homing, soft-limits, step-calibration etc) but since I'm moving over from a 3d printing setup, I'm not sure what other commands I'd need setup
      If someone could even just list out the codes that i might need to play around with I'd be immensely grateful
      Many thanks
      EDIT: Further question sorry for anyone who uses F360 for their cutting: I've managed to blunder my way through Fusion360's manufacturing section and I'm ready to output the file (post process it?), but it only wants to give me a .nc file rather than a .gcode even though I'm picking Grbl. Do I just re-name the file or something?
      A Former User 1 Reply Last reply Reply Quote 0
      • A Former User
        A Former User last edited by
        The only CNC specifc config is https://duet3d.dozuki.com/Wiki/Gcode#Section_M453_Select_CNC_Printer_Mode
        Work coordinates are described in G10 and G54
        https://duet3d.dozuki.com/Wiki/Gcode#Section_G10_Set_workplace_coordinate_offset_or_tool_offset
        https://duet3d.dozuki.com/Wiki/Gcode#Section_G54_to_G59_3_Select_coordinate_system
        • Asdasd1234
          Thanks @bearer
          • A Former User
            A Former User @Asdasd1234 last edited by
            @Asdasd1234 said in Is there a basic guide to set the duet up as a CNC:
            yeah the post processor will output gcode but the extension is .nc by default
              dc42 administrators @Guest last edited by
              See also https://duet3d.dozuki.com/Wiki/Configuring_RepRapFirmware_for_a_CNC_machine.
              • Asdasd1234
                thanks guys ill read into this now
                • Asdasd1234
                  Ok so am I right in saying :
                  • I have a gcode file (just a re-named .nc file from fusion 360)
                  • I home my machine using g28.
                  • I jog the machine to the start of the file gcode
                  • Use G10 L20 P2 X0 Y0 Z0 To set the co-ords for the start of the file.
                  • then run the file?
                  How do I ensure the file runs using the work co-ords and not the machine co-ords? Do I need to specify it at the start of the file?
                  A Former User Danal 3 Replies Last reply Reply Quote 0
                  • A Former User
                    Think there is an option in your post processor to either run G28 or G54 at the start of the exported g-code? Been awhile since I've messed with that stuff. You can review the top of the exported g-code to verify what you get.
                    • Danal
                      Danal last edited by
                      All CNC machines that follow G-Code standards are always in a work coordinate system.* The default at power up is G54. When you do the G10 L20 P2, you are setting the "second" system, namely G55.
                      Therefore, you can have a G55 at the very start of your file, or issue a G55 via the Web interface.
                      * Always, with the single exception of an individual line that starts with G53, which will operate in machine coordinates. G53 is not 'sticky' and therefore applies to only the line where it appears.
                      Asdasd1234 1 Reply Last reply Reply Quote 0
                      • Asdasd1234
                        Asdasd1234 @Danal last edited by Asdasd1234
                        @Danal
                        Ah, so I could do the following?
                        • G28 home the machine
                        • Jog machine to start of file.
                        • Run macro that does:
                          -G10 L20 P2 X0 Y0 Z0
                          -G55
                        • Then run the file?
                        Sorry for all the questions, I just realllly dont want to crash the machine into an axis or the bed etc
                        Danal dc42 2 Replies Last reply Reply Quote 0
                        • Danal
                          Danal @Asdasd1234 last edited by Danal
                          You are basically correct, here is a slight rephrasing of a couple of lines, just for clarity.
                          • I have a gcode file (just a re-named .nc file from fusion 360) Correct, upload that file via the Web interface
                          • I home my machine using g28. Correct
                          • I jog the machine to the start of the file gcode to the tip of the cutter just touching the origin of the stock. Normally in the 'lower left' corner, and just touching top-of-stock in Z.
                          • Use G10 L20 P2 X0 Y0 Z0 To set the co-ords for the start of the file. the second work-coordinate-system (G55) to match the physical object I want to cut
                          • then run the file? Issue a G55, then, Yes, in the Jobs tab, click then file, then OK
                          • Danal
                            -G55
                            Then run the file?
                            Yes
                            • Asdasd1234
                              @Danal
                              Thats great, I'll try that now. Thanks a bunch for the help people. Its much appreciated
                              • Danal
                                No problem.
                                This does assume you've set Z0 to top of stock in Fusion. This is a fairly normal CNC practice.
                                • Asdasd1234
                                  @Danal
                                  I'm pretty sure I have, but will double check
                                  • Asdasd1234
                                    Ah, I might have an issue.
                                    F360, when set to grbl only lists out the co-ordinates and doesn't do a G1/0 before them like:
                                    G1 Z1 F500
                                    Z-1.999
                                    Y26.033 Z-2 F1200
                                    Y26.034
                                    X28.967 Y26.035
                                    X28.595 Y26.047
                                    X28.194 Y26.057
                                    X27.792 Y26.067
                                    Will this still work?
                                    • Danal
                                      No. Duet doesn't support "sticky" G1 or G0. You will need to select a different post processor, or modify that one.
                                      • Danal
                                        I use Mach3 post. Which isn't perfect, but it does put G1 on each line.
                                        • Asdasd1234
                                          i found a post processor online for duet. I need to manually delete out the G54 at the start, but my test pen-plot has come out perfect. Thanks a bunch!
                                          • A Former User
                                            A Former User @Asdasd1234 last edited by A Former User
                                            you can edit the .cps file and change the line that says (line 28 in the grbl if thats what you used)
                                            extension = "nc";
                                            to say
                                            extension = "gcode";
                                            to not have to do the renaming.
                                            try putting a "2" in WCS offset here if you wanted G55 instead.
                                            Setup -> Post process tab:
                                            (edit: or you could edit the file and change 1 to 2 in line 353 to make it permament and not have to set it each time.)
                                            ((or search for var workOffset = currentSection.workOffset;and change workOffset = 1; to workOffset = 2; a few lines below if your post is different from the grbl))
                                            (((or if you just wanted to get rid of the whole G54 thing try changeing the Safe retracts parameter in the post to ClearanceHeight
                                            bc723522-0a24-4561-9959-30403c9e2562-image.png )))
                                            dc42 1 Reply Last reply Reply Quote 1
                                              dc42 administrators @Danal last edited by
                                              @Danal said in Is there a basic guide to set the duet up as a CNC:
                                              Yes it does, when in CNC mode and using recent firmware versions (2.05 or 3.x).
                                              Danal 1 Reply Last reply Reply Quote 0
                                                @bearer said in Is there a basic guide to set the duet up as a CNC:
                                                extension = "nc";
                                                to say
                                                You don't have to rename anyway. DWC and RRF accept .nc files.
                                                  dc42 administrators @Asdasd1234 last edited by
                                                  -G55
                                                  Alternatively, use P1 in the G10 command instead of P2, then you don't need the G55.
                                                  • Danal
                                                    Danal @dc42 last edited by
                                                    @dc42 said in Is there a basic guide to set the duet up as a CNC:
                                                    Ah... I tried it, but not in CNC mode... grasshopper learns from master once again. 🙂
                                                    • Danal
                                                      -G55
                                                      This is true... but... a lot of people like to leave G54 matching machine, because there the controller is always in some Work Coordinate System, and it just makes more sense for the human to have G54 match the physical layout of the device, G55 match the first fixture, G56 the second fixture and so forth.
                                                      Again, there is no "right or wrong" here... and some people do it a completely different way... the most common practice I've seen is leaving G54 alone (or, technically, G54 has a 0,0,0 offset to G53).
