    Duet 2 wifi with DuetPi
    221
    • BearcatTD
      BearcatTD last edited by
      Can a Duet 2 wifi be used with DuetPi? The instructions talk about Duet3 but it doesn't say that it is not possible with the Duet2 wifi!
      Thanks,
      Pat
      Professor of Theatre, Lighting and Scenic Designer, Northwest Missouri State University
      Hardware: Ender 3 with a Duet 2 wifi, CR-10 V2 with a Duet3
      • gtj0
        gtj0 last edited by
        Currently no. The Pi communicates with the Duet3 using the SPI bus which on the Duet2s is used by the network modules. The Duet3D team is thinking about how to make it work but it probably won't be soon.
        • A Former User
          A Former User last edited by
          While the only difference between the Duet 2 Wifi and the Duet 2 Ethernet is the network module, the Wifi is soldered in place and the Ethernet is plugged in so unless you can desolder the Wifi module you cannot use the Duet 2 Wifi with a single board computer like the Raspberry Pi even after the Duet 2 fimware supports this.
          (Maaaaybe you could make up a Wifi Firmware that simply leaves the SPI bus unused and then solder on some wires to make up the connection to the Raspberry Pi, but you'll have to wait and see what the community comes up for retrofitting I guess. New boards will be the Ethernet without Ethernet until they redesign it from whats been posted so far)
          • gtj0
            gtj0 last edited by
            I only have a Duet2 Ethernet so I didn't know the Wifi module was soldered in. Good to know.
            • jay_s_uk
              jay_s_uk last edited by
              The LPC Port of reprapfirmware has a very hacky but working version of duetpi connected to a board via SPI
              • BearcatTD
                Thanks Jay! Is there information on this anywhere?
                • A Former User
                  Might find something over at the LPC port https://github.com/sdavi/RepRapFirmware
                  Mind you it'll likely not solve the problem of removing or disabling your wifi module (not to mention LPC binaries will not work Duet boards with Atmel microcontrollers)
                  • Danal
                    Danal last edited by
                    Curious what your goal is? There may be another way...
