    ender 5 plus help
    383
    • nightmare90gt
      nightmare90gt last edited by
      I have swapped in the duet 2 wifi but having a little trouble getting the printer to operate correctly.
      1. the filament sensor isn't working at all I have it plugged into E0 stop and inserted
        ; Filament runout sensor
        M581 E1 T1 S0 C1 ; Filament run-out sensor triggers a pause
        into the config.g file have had no luck. I am using the original sensor that came with the printer
      2. when I am trying to get the trigger height for the BLtouch it doesn't display in the G-Code console and everytime I make adjustments it just simply adds to the z position. The BLtouch is setup as the z endstop but unsure if its also the bed leveler.
      Any help is appreciated.
      • droftarts
        droftarts Moderator @nightmare90gt last edited by
        @nightmare90gt ideally, post your full config.g and response to M115. Also post you homeall.g and homez.g.
        1. Use M591 for filament sensor, not M581; see https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing and https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_filament-out_sensors
        2. Not sure how you are currently setting Z trigger height, but this is the way to do it: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
        • nightmare90gt
          m115
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
          config.g
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Mar 15 2020 12:19:59 GMT+0100 (Central European Standard Time)
          M550 P"Ender 5 plus" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P3 S0 ; physical drive 3 goes backwards
          M350 X32 Y32 Z32 E64 I1 ; Configure microstepping with interpolation
          M92 X160.00 Y160.00 Z1600.00 E407.44 ; Set steps per mm
          M566 X900.00 Y900.00 Z180.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z1200.00 E1200.00 ; Set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z100.00 E250.00 ; Set accelerations (mm/s^2)
          M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X350 Y350 Z400 S0 ; set axis maxima
          M574 X1 Y1 S1 ; set active high endstops
          M574 Z2 S2 ; set endstops controlled by probe
          M574 X1 Y1 Z0 E0 S1 ; set filament runout sensor
          M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
          M558 P9 H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X48 Y10 Z3.00 ; set Z probe trigger value, offset and trigger height
          M557 X50:300 Y10:340 S30 ; define mesh grid
          M305 P0 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 0
          M305 P1 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 1
          M106 P0 S0 I0 F20 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F20 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
          T0 ; select first tool
          • nightmare90gt
            ; homeall.g
            ; called to home all axes
            G91 ; relative positioning
            G1 H1 X-355 Y-355 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-355 Y-355 F360 ; move slowly to X and Y axis endstops once more (second pass)
            G90 ; absolute positioning
            G1 X175 Y175 F6000 ; go to first bed probe point and home Z
            G1 X0 Y0 Z0 F100 ; lift Z relative to current position
            ; homez.g
            ; called to home the Z axis
            G1 X30 Y30 F6000 ; go to first probe point
            ;G91 ; relative positioning
            ;G1 Z0 F100 ; lift Z relative to current position
            ;G90 ; absolute positioning
              Have you followed this?
              3mm trigger height seems a bit too high for the BLTouch. When mounted the base of the probe should be ~8mm above the nozzle tip, which will lead to a trigger height of ~2mm. This is important to get right because you don't want to pin to be too low during a print and get caught, and you don't want the nozzle tip to be below the probe pin when probing as you'll get a head crash.
              Also take a look here: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s229
              • Veti
                Veti last edited by
                @nightmare90gt said in ender 5 plus help:
                your config says duet wifi, but interpolation like this only works on the maestro or duet3
                nightmare90gt 1 Reply Last reply Reply Quote 1
                • nightmare90gt
                  nightmare90gt @Veti last edited by
                  @Veti would I just take the i1 out of the code.
                    It would be better to use x16 microstepping with interpolation enabled. Your motors will be quieter and smoother.
                    X64 on the extruder is ok since it gets you up to 400 ish steps per mm, which is good.
                    M350 X16 Y16 Z16 E64 I1
                    And don't forget to adjust your steps per mm for the X Y Z axis as well.
                    • nightmare90gt
                      The 591 didnt work for the filament sensor the extruder will still move with no filament.
                      I will change the microstepping to 16 later today.
                      • droftarts
                        Please post the M591 command you are using. Note that filament sensing is only active when printing from SD card. You can see the status by sending M591 D[extruder_drive_number], and it should say if filament is present or not.
                        • nightmare90gt
                          M591 E1 T1 S0 C1
                          Sent M591 D3 got nothing.
                          • droftarts
                            @nightmare90gt Please read the M591 documentation I posted in reply to your first post: https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
                            Your M591 command is wrong. You need D, P, C and S parameters in M591, where D is the extruder drive, P is the sensor type, C is the endstop pin, and S is enable.
                            Shamusseven 1 Reply Last reply Reply Quote 0
                            • Shamusseven
                              Shamusseven @droftarts last edited by
                              @droftarts I am wanting to set my Ender 5 plus filament sensor up to my duet2wifi as well. Can anyone tell me what type of sensor it is to place in the Pnn parameter? And can the original connector / wiring be used?
