    Jerky movement in X axis when carving
    CNC
    163
    • A Former User
      A Former User last edited by
      I just did my first real carving since setting up my custom CNC and it seems to move very jerky in the X axis direction while carving. When i move it from location to location its great, super smooth no issue but when its doing a 3d carving moving slow in the X direction it seems to struggle then jump.
      3DPMicro 1 Reply Last reply Reply Quote 0
        More technical details please.
        A Former User 1 Reply Last reply Reply Quote 0
        • 3DPMicro
          3DPMicro @Guest last edited by
          @chichirod by 3d carving do you mean all 3 axis moving at the same time? If so post the g code program for those moves
          • A Former User
            A Former User @3DPMicro last edited by
            @3DPMicro The machine is only moving the X axis and Z axis when the jerkiness seems to happen. When its running at a consistant level its very smooth but as it lifts to carve a piece it jumps instead of being a smooth transition. Here is the Gcode:Eagle rough 2 0.25em.gcode
              Config please. Sounds like Z speed settings could be too low
              • A Former User
                A Former User @Phaedrux last edited by
                @Phaedrux The machine is only moving the X axis and Z axis when the jerkiness seems to happen. When its running at a consistent (not lowering or raising the Z axis) level its very smooth and quick, but as it lifts to carve a piece it jumps instead of being a smooth transition.
                • A Former User
                  @Phaedrux ; Configuration file for Duet 3 (firmware version 3)
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Mar 06 2020 14:56:26 GMT-0700 (Mountain Standard Time)
                  M550 P"Duet3 CNC" ; set printer name
                  M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M569 P0.1 S0 ; physical drive 0.1 goes backwards
                  M569 P0.2 S0 ; physical drive 0.2 goes backwards
                  M569 P0.3 S0 ; physical drive 0.3 goes backwards
                  M584 X0.0:0.3 Y0.1 Z0.2 ; set drive mapping
                  M92 X80.00 Y80.00 Z400.00 E80.00 ; set steps per mm
                  M566 X900.00 Y900.00 Z12.00 E900.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X12000.00 Y12000.00 Z1800.00 E12000.00 ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z20.00 E500.00 ; set accelerations (mm/s^2)
                  M906 X2800 Y2800 Z4200 E2800 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X2498 Y1245 Z140 S0 ; set axis maxima
                  M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
                  M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
                  M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in
                  M558 P0 H5 F120 T12000 ; disable Z probe but set dive height, probe speed and travel speed
                  M557 X15:215 Y15:195 S20 ; define mesh grid
                  M308 S0 P"temp0" Y"thermistor" T1 B4138 ; configure sensor 0 as thermistor on pin temp0
                  M143 H0 S0 ; set temperature limit for heater 0 to 0C
                  M307 H0 B0 S0.00 ; disable bang-bang mode for the bed heater and set PWM limit
                  ; Custom settings
                  M307 H1 A-1 C-1 D-1 ; Disable Heater 1 so we can use it for a tool
                  M453 P0 R24000 F400 ; Set to CNC mode, using Tool 0, 24000 Max RPM, PWM Frequency 400hz
                    Yes increase your zspeeds acceleration and jerk. Do some testing to see if it's still in the limits and try again. Dry run first.
                    • A Former User
                      @Phaedrux Awesome, thank you. Any recommendations on how high to go to?
                        That's what the testing is for, but Start with 10x your current values. It's the 12mm/min jerk that is the biggest problem I think.
                        A Former User 2 Replies Last reply Reply Quote 0
                        • A Former User
                          @Phaedrux Ok, I just wanted a starting point. Ill start playing. Thank you
                          • A Former User
                            @Phaedrux That was definitely it. It moves way better. A bit more tweaking and its all good
