Macro doesnt work!
  • Hello together!
    I am new here and this is also my first hevo which i am building and my first duet 2 wifi board ever...
    so please be forgiving if I do something wrong or something is my mistake
    I create a Macro called "Motoren deaktivieren" and in this Macro i put the M84 command!
    After Saving and exeuting the macro i can move to axis, so this was successfully!
    BUT, if i write comments in the macro like this:
    M84 #Motoren deaktivieren
    and save & execute this again, nothing will be happen.
    No error or other, but i also can NOT move the Axis?
    what is wrong here?
    I am Using a DUet 2 Wifi with the lates 2.x Firmware and the latest Webfirmware from Github!
    Thanks & Kind Regards
  • @xenon2008 said in Macro doesnt work!:
    you have to use a semicolon for the commend try M84 ;Motoren deaktivieren
  • ohhhh! thanks, i will try it as soon as the current printing is finished. my first xy calibration cube * I'm proud *
    do I need a semicolon for all commands?
  • the semicolon is used to indicate that whatever follows, until the end of the line, is a comment
  • okay thank you very much for the quick and friendly answer 😃
