    Emergency Stop Firmware 3.0
    • CupaCabra
      CupaCabra last edited by
      I have a little bit trouble with my Emergency Stop Button.
      So I use the Firmware Version 3.
      The wire I have take on Pin "e2stop" and grd.
      in my config i have take the code
      M581 P"e2_stop" T0 C0
      if i write M582 T2 in the console i take Nothink back.
      what´s the prob.
      i would later a custom scipt to leave the current possition and lower Z
      ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 09:19:35 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"My Printer" ; set printer name
      M667 S1 ; select CoreXY mode
      M551 P"123" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z4257.9 E435.00:435.00 ; set steps per mm (Z4257.90)
      M566 X1000.00 Y1000.00 Z150.00 E1200.00:1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z360.00 E2400.00:2400.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z500.00 E2000.00:2000.00 ; set accelerations (mm/s^2) standard=x2000.00 y2000.00
      M906 X1000 Y1000 Z1200 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X350 Y350 Z450 S0 ; set axis maxima
      M574 X2 S1 P"!xstop"
      M574 Y2 S1 P"!ystop"
      M574 Z2 S2
      ;M574 e2stop S1
      M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-17,5 Y15 Z1.30 ; set Z probe trigger value, offset and trigger height
      M557 X30:350 Y30:350 S40 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T100000 B4100 ; configure sensor 1 as thermistor on pin e0temp
      M308 S2 P"e1temp" Y"thermistor" T100000 B4100 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M307 H2 B0 S1.00
      M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on
      M563 P1 D1 H2 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      M501 ;Load saved parameters
      ;FilamentSenoren
      M591 D0 P2 C"e0_stop" S1
      M591 D0
      M591 D1 P2 C"e1_stop" S1
      M591 D1
      ; *** Panic Button
        Please upgrade to release 3.01-RC4 and check whether the problem still occurs. The code to handle triggers has been largely rewritten since version 3.0. Note, the M581 syntax has been changed.
        • CupaCabra
          🙂 I make tomorrow the Upgrade.
          Thx 4 the help.
          The BL-Touch config are the Same.
          • deckingman
            deckingman @CupaCabra last edited by
            @CupaCabra If your were on RC2 or later, (and so if you upgrade to RC4) you first need to create an input pin using M950 with the J parameter,
            https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M950_Create_heater_fan_or_GPIO_servo_pin
            then use the P parameter to refer to this pin in your M581 command
            https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M581_RepRapFirmware_3_01RC2_and_later
            • arhi
              arhi last edited by
              For the bltouch make sure you add ^ (turn on pullup) to the pin name, it is off since rc2 IIRC. Might be required for the STOP too if you are just going to use that pin and GND.
              • CupaCabra
                Hello, Now I have install the new Firmware 3.01 RC4.
                But the config don’t won’t Trigger or make everything.
                M950 J1 C“e2stop“
                M581 P0:3 S1 T2 C1
                The GCode M582 T2 return nothing.
                • CupaCabra
                  CupaCabra last edited by CupaCabra
                  Now I read in the Doku. the right name of e2stop are exp.e2stop
                  Are the right code
                  M950 J1 C"^exp.e2stop”
                  M581 P0:3 S1 T0 C0
