    PanelDue checksum errors
    196
    • joeko
      joeko last edited by joeko
      hallo,
      i have checksum Errors when the Printer heat the bed or nozzle. not when the axis moves or when no Job is running. the Frame and the psu negative Output are grounded. it is the duet 2 Ethernet and the paneldue 4.3 with Firmware 2.232 and 2051 fror the duet.
      M122 give this
      SENDING:M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet Ethernet 1.02 or later
      Board ID: 08DGM-917NK-F2MSW-6JKDD-3S06N-TZ40D
      Used output buffers: 2 of 24 (10 max)
      Static ram: 25712
      Dynamic ram: 92804 of which 0 recycled
      Exception stack ram used: 320
      Never used ram: 12236
      Tasks: NETWORK(ready,1608) HEAT(blocked,1232) MAIN(running,3736) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:07:13 ago, cause: power up
      Last software reset at 2020-03-22 23:16, reason: User, spinning module GCodes, available RAM 12236 bytes (slot 1)
      Error status: 0
      [ERROR] Error status: 0
      Free file entries: 10
      MCU temperature: min 38.2, current 38.7, max 39.1
      Supply voltage: min 23.8, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Cache data hit count 798604022
      Slowest loop: 4.21ms; fastest: 0.08ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Heater 0 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "M122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.07ms; fastest: 0.04ms
      HTTP sessions: 0 of 8
      Interface state 5, link 100Mbps full duplex
      === Filament sensors ===
      Extruder 0 sensor: ok
      the config.g
      M80 ; Auto shutdown
      M550 P"Ender 5 plus" ; set printer name
      M552 P192.168.250.38 S1 ; enable network and set IP address
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.250.1 ; set gateway
      M575 P1 B57600 S0 ; Set auxiliary serial port baud rate and require checksum (for PanelDue)
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      ;Filament Sensor
      M591 D0 P1 C3 S1 ;Filament Sensor Typ 1 fuer drive 0 an E0 angeschlossen
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P3 S0 ; physical drive 3 goes backwards
      M92 X80.00 Y80.00 Z800.00 E393.30 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z480.00 E1500.00 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X330 Y330 Z400 S0 ; set axis maxima
      M574 X2 Y2 S1 ; set active high endstops
      M574 Z1 S2 ; set endstops controlled by probe
      M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-42 Y0 Z2.75 ; set Z probe trigger value, offset and trigger height
      M557 X20:300 Y20:300 S70 ; define mesh grid
      M305 P0 T100000 B4138 R4700 X2 ; set thermistor + ADC parameters for heater 0 and remap it to channel 2
      M143 H0 S110 ; set temperature limit for heater 0 to 110C
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
      M143 H1 S285 ; set temperature limit for heater 1 to 285C
      M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T50 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      i use the 4 pin cable but with the Ribbon is it the same. also i checked the sd Card and the Panel is now outside of the Printer. i can finish the printjobs
      yesterday i got the message
      Last reset 00:32:54 ago, cause: power up
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 12280 bytes (slot 2)
      Error status: 8
      [ERROR] Error status: 8
      • joeko
        no one an idea ?
        i checked more and i get only checksum errors when i heat the bed.
        Frame and negative out from the psu are grounded. i use the 4 wire cable that was included of the panelduo. when i Interrupt the cable from the mofset to the bed i dont get Errors.
        is it possible that the psu (500w from the ender 5 plus) dosnt has enough power ? i saw on YouTube an psu test About this Printer and the result was that the psu doesnt has not enough power...the Errors (checksum error on line 412 and so on) appear after start the bed heating
        rerouting the cable doesnt Change it and the Motor Driver are not close
        • droftarts
          droftarts administrators @joeko last edited by
          @joeko I’d guess that your bed is in PWM heater mode, and the frequency is interfering with PanelDue comms. What M307 heater settings are in config_override.g?
          Or you have a ground issue, and the bed is feeding voltage back. Is it a mains heater, or running off a separate PSU?
          Lastly, could be a failing PSU that’s struggling when the bed is on.
          For the error see https://duet3d.dozuki.com/Wiki/Error_codes_and_software_reset_codes
          I think it means it was an output stack overflow, which I think is caused by an unresponsive PanelDue, but could be wrong.
          • joeko
            hmm, there are no config_override.g …...
            how do i create one ?
            what do you mean with mains heater ?
            the bed is connect to a mofset and the duet bed Control this mofset. i have only one psu.
            today i saw the red light from the bltouch short flashing as i start the bed heating. but when is check the voltage from the psu i dont see big voltage droping when i heat the bed.
            • droftarts
              @joeko you have M501 at the end of your config.g and no M307 tuning, so I assumed you had them in config_override.g. If you don’t you’re using default parameters.
              I didn’t see your other reply when I was writing mine, so was just speculating about the bed heater.
              I think this is, as you said in your earlier post, an underpowered PSU causing the issues. I guess it’s reducing current but holding the voltage, somehow.
              • joeko
                good morning,
                i ordered a new mean vell 500w psu. now i wait for it and give feedback than
                but can i check the option with the config_override.g ? how i change the frequency for pmw ?
                i come from marlin and here the most Things are new
                • joeko
                  here is the check from th3d about the stock psu. it start at 9:50 min
                  https://www.th3dstudio.com/product/ender-5-plus-meanwell-psu-replacement-450w-24v-18a-real-output/
                  is it possible that this produce the error from the panelduo ?
                  • droftarts
                    @joeko Thanks for the video link. Hard to say if that's the cause, but seems pretty likely the underpowered PSU is causing problems.
                    For tuning the heating of the bed and hotend (which should lead to more stable temperatures) see https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                    You can do this for both hot end and heated bed, and you can use PWM heating on the bed rather than bang-bang. I'd wait until the new PSU is fitted, though.
                    joeko 1 Reply Last reply Reply Quote 0
                    • joeko
                      joeko @droftarts last edited by
                      @droftarts
                      thank you for the Help.
                      I will do that after i received the new psu. But now i remind me that the bed is bang-bang controlled
                      • joeko
                        the new psu is fitted and there are no Errors when i heat the bed 🙂
                        with the stock psu i got after 1-2 minutes checksum Errors and now no Errors after 60 minutes
