3 Motor Z axis Automatic bed levelling using G32 RRF 3.01-rc3
I cannot make sense out of your bed.g file and your M671 command.
What are the X and Y axis min/max values?
Do you have a diagram showing the position of your lead screws in relation to the bed?
@fcwilt Thank you for your response,
i just noticed that I used commata instead of decimal points at the M671 command, what could be problematic...
The x-Coordiantes of the leadscrews are +396mm, +171mm and -54 mm. The y-Coordinates of the leadscrews are -86.82mm, +235,88mm and -86.82mm. The S parameter allows height correction up to 5mm per leadscrew.This is my config.g
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards (X-Motor) M569 P1 S1 ; physical drive 1 goes forwards (Y-Motor) M569 P2 S1 ; physical drive 2 goes forwards (Z-Motor front left) M569 P3 S1 ; physical drive 3 goes forwards (Z-Motor back mid) M569 P4 S1 ; physical drive 4 goes forwards (Z-Motor front right) M569 P5 S1 ; physical drive 5 goes forwards (Extruder1) M584 X0 Y1 Z2:3:4 E5 ; set drive mapping (0-X, 1-Y, 2,3,4-Z, 5-E) M669 K1 ; select CoreXY mode (Muss nach M584 kommen, da dort neue Achsen definiert werden) M671 X-396:171:-54 Y--86,82:235,88:-86,82 S5 ; Coordiantes of the three Z-Leadscrews M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z1600 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X3000.00 Y3000.00 Z100.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X1330 Y1330 Z1330 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X320 Y272 Z300 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop+e0stop+e1stop" ; configure active-high endstops for low end on Z via pin zstop ; Z-Probe M558 P9 C"^zprobe.in" H10 F150 T2000 ; BL-Touch Implementation: Set Input Pin M950 S2 C"duex.pwm5" ; BL-Touch Implementation: Set PWM Pin G31 X0 Y-47.53 Z2.7 P25 ; BL-Touch Implementation: Set Z probe trigger value, offset and trigger height M557 X25:105 Y25:105 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
Before running my bed.g file, I home every axis with the opctical endstops at every leadscrew. Because this is not that exact, I want to level the bed using the BL-Touch afterwards. To Do this, i reconfig the endstop definition like this:
M574 Z1 P"nil" ; deactivate leadscrew endstops M574 Z1 S2 ; Z1: Enstop at low end, S2: Using Z-Probe
After that is done, i run my bed.g
I hope you understand better what I did there now
Greetings,
Lasko -
In the M671 command you have a hyphen after the X and the Y. Why is that?
I don't know if commas are allowed in place of decimal points.
And unless I am confused there is no reason to disable your Z end stops to use the Z probe for auto bed leveling.
I didn't when I experimented with auto bed leveling and it all worked fine.
@Lasko Please create a new thread for your issue rather than tacking on to the end of someone else's solved issue.
@Phaedrux
I would do it, but my problem got solved by @frederikvThe problem was the commata and the "-" in the M671 command
I chnaged a lot of code because it didn't work as I wanted for a long time. Thank you @frederikv for the Help!
Greetings,
Lasko
