    Fan Config Maestro
    • KennyC
      KennyC last edited by
      Some Help Please, I've been at this for 3 days !!
      Wiring is sound,
      Fan 0 Part cooling
      Fan 1 Hot end
      I cannot make the part cooling fan work.
      If I swap connections the part cooling fan works but the hot end, hot end fan and LED's on the smart effector will not.
      This is driving me spare, any assistance would be appreciated.
      ; Configuration file for Duet Maestro (firmware version 2.03)
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Mar 21 2020 22:23:28 GMT+0000 (Greenwich Mean Time)
      M550 P"Predator" ; set printer name
      M665 R227 L440.42 B85 H410 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P3 S0 ; physical drive 3 goes backwards
      M350 E16 I0 ; configure microstepping without interpolation
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z160.00 E436.54 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X2 Y2 Z2 S1 ; set active high endstops
      M558 P8 R0.4 F1200 ; set Z probe type to effector and the dive height + speeds
      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P100 X0 Y0 Z-0.1 ; set Z probe trigger value, offset and trigger height
      M557 R85 S20 ; define mesh grid
      M305 P0 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4725 C7.060000e-8 R2200 ; set thermistor + ADC parameters for heater 1
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      • PaulHew
        PaulHew last edited by
        Can you paste the results of M115, please.
        So you cannot control the fan from DWC using the slider?
        The fan works directly connected to the PSU?
        Try taking the F500 out of that line, it will make it use the default PWM frequency of 250
        From the GCode bible https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
        The F parameter sets the fan PWM frequency, in Hz. The default is F250, which works with most fans, Try F100 or lower if you find that you can't control the speed of your fan.
        HTH
        Paul.
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        KennyC 1 Reply Last reply Reply Quote 0
        • jens55
          jens55 last edited by
          Sounds to me like you have borked (technical term) the fan 0 output.
          I don't know if the Maestro has extra fan outputs but if it does, I would use one of those spare outputs and see if you can get it going that way. If that works then it is likely a defective output FET on the fan 0 line.
          • KennyC
            KennyC @PaulHew last edited by
            Hi Paul many thanks for your reply,
            M115
            FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-02-09b1
            Fan works fine connected to PSU
            On Fan 0 the Fan does not work at all.
            If I connect it to Fan 1 it works and I can control the speed with the slider in DWC
            However the hot end ,hot end fan and LED's on the smart effector does not work on Fan 0
            I can change the Part cooling fan to Fan 2 and it works but is really under powered.
            Thanks Kenny.
              dc42 administrators @KennyC last edited by
              @KennyC said in Fan Config Maestro:
              Do you have the voltage select jumper for Fan 2 set to the correct position? On the Maestro, fan 2 is separately selectable between VIN and 5V.
              • KennyC
                KennyC @dc42 last edited by
                Many Thanks for that, Nope I had not, Thankfully now working,
                Any Thoughts on why Fan 0 is inop?
                Thanks Kenny.
