    Duet Wifi at 15V with 12V Fan and Heater?
    • rot
      rot last edited by
      i use a Duet Wifi with actually 12V.
      But this power source is getting old and I should replace it.
      Now I have from another hobby an 15V 350W power adapter.
      It should be possible to use this Power adapter with my actual setup with 12V Fans and heater
      if I change the maximum PWM to 80%.
      That should give me the same effective voltage for the heater and the fans.
      Did somebody try that?
      Regards,
      Stefan
      • A Former User
        It would work fine with heaters, not so sure about the fans as they will still see 15v peaks. It may well work, for a while.
        You'd be better off using a dc/dc converter to drop the voltage for the fans.
        Edit; I might not bother dropping the duty cycle for the heaters if the wiring and connectors can handle it; just re-tune the heaters for the new voltage. You'll get the same warning about over powered heaters anyway, i.e. it won't be any safer, only slower.
        • jens55
          jens55 last edited by
          You will be just fine with the increased voltage and as bearer says, re-tune the heaters. You will however find that you might need to change the duty cycle to 60% as power = current * voltage squared.
            To reduce the fan voltage back to 12V, you could remove the VFAN jumper and replace it with 3 silicon diodes connected in series, between the VIN pin of that jumper block and the centre pin. Keep clear of the 5V pin!
            • rot
              rot last edited by
              Ok, thanks for your answers.
              I will try that 🙂
