    12V LED Strip ond Duet 2 Wifi
    254
    • xenon2008
      xenon2008 last edited by
      Hello!
      Can i connect a 12V LED Stripe to a controlled FAN Output?
      I have 24V System, but when i wire +/- from the Controlled Fan Output to to Buck Regulator (12V), and from the Buck Regulator to the 12V LED Stripe, that should work?
      And if yes, what have i to set in the Firmware?
      Sorry for my Bad English, i am a German User with terrible English Skills 😃
      Thanks & Kind Regards
        Yes that should work.
        How do you have the buck converter wired up to the fan ports?
        See here for an illustrated example
        Buck converter: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s214
        LEDs: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s225
        xenon2008 1 Reply Last reply Reply Quote 0
        • Danal
          Danal last edited by Danal
          Your english seems very good.
          Be aware that the regulator should be in the + (positive) (red) side. The buck regulator should have its own ground, NOT to the fan output.
          The fan output PWM switches the ground - (negative) (black) side. The fan output negative should be wired directly to the black wires from the LED strip.
          @xenon2008 said in 12V LED Strip ond Duet 2 Wifi:
          Define that fan port as a fan, then use normal fan on, or fan off, commands to turn the LEDs on or off.
          • xenon2008
            xenon2008 @Phaedrux last edited by
            @Phaedrux said in 12V LED Strip ond Duet 2 Wifi:
            so far i haven't soldered the buck converter yet because i wanted to ask beforehand
            @Danal said in 12V LED Strip ond Duet 2 Wifi:
            I don't quite understand that now ...
            I have a 12V Fan connected with a Buckregulator as described here
            how do I have to attach the LED strip where exactly or the buck converter?
            Kind Regards
            • Danal
              Buck regulator input + (red) to + of an always on fan outlet on the Duet.
              Buck regulator input - (black) to - of an always on fan outlet on the Duet.
              Buck regulator output + (red) to the + of the fan itself.
              Buck regulator output - (black) will have no connection.
              Fan - (black) to the - of the controlled fan outlet on the Duet.
              Which Duet board do you have? Duet 2 Wifi? Duet 3 6HC? I will post a wiring diagram.
              • xenon2008
                xenon2008 @Danal last edited by
                that's exactly how i connected the fan
                and that's exactly how I should now attach the LED bar?
                I have an Duet 2 Wifi
                • Danal
                  • xenon2008
                    Thanks!
                    Thats 1:1 the same as i have it already at my 12V Partcooling Fan 😉
