    Thermistor issue
    • ron9041
      ron9041 last edited by
      I was having issues with my beds thermistor so I swapped it with one from an old hot end. I changed the config as needed and read 2000c. I hooked it directly without an extension I was using and it reads fine. The wire gauge is similar. The extension came with it from the old hotend. Thoughts?
        Bad crimp or broken wire in the extension.
        • ron9041
          true enough, been using the extension for another part but it was held in such a way that worked and I did not notice that it was not a good connection.
          • Danal
            Danal last edited by Danal
            Open/broken normally reads -273.
            2000 is more indicative of a short in that harness.
