    Duex5 red led on next to the E2 heat
    • tekstyle
      tekstyle last edited by tekstyle
      I tried to run my first test print today but I guess something went wrong and now I have a red LED next to the E2 heater pin. I checked the voltage and it shows 24v. I checked all the other heater pins and they are 0v. In DWC2, the standby and active temperature for E2 is 0 and 0 so I dont know why it is still on?
      The red led and voltage reads 24v upon powering up the system. Can't seem to turn it off.
      tekstyle 1 Reply Last reply Reply Quote 0
      • tekstyle
        tekstyle @tekstyle last edited by
        @tekstyle any help? I ran a test of the e2 mosfet with a dmm. Source and drain is continuous
        A Former User 1 Reply Last reply Reply Quote 0
        • A Former User
          A Former User @tekstyle last edited by
          @tekstyle said in Duex5 red led on next to the E2 heat:
          in both polarities? if so sounds the output mosfet failed.
            Are you using any of the PWM outputs on the DueX, for example H3 for a BLTouch? They share the heater channels.
            • tekstyle
              tekstyle @dc42 last edited by
              @dc42 no I am not. But I was running a 12v heater before I realized it wasnt 24v. I didn't pwn the heater to reduce power.
              • tekstyle
                tekstyle @Guest last edited by
                @bearer I believe so. In both directions
