    Sensorless homing tuning on cartesian printer
    227
    • FelixH
      FelixH last edited by
      Hi all,
      First of all, I hope you are all safe an healthy. Be strong.
      I installed yet another Duet to one of my cartesian machines. I decided to try the sensorless homing feature, just to save me from routing two additional cables and installing end-stops. The machine previously run on 2130s on X and Y and it just made sense to me.
      Most of the transition has been painless, but now it comes the sensorless homing. Searching around I found starting settings for my config.g, homeall.g, homex.g, homey.h and homez.g (Z axis has an inductive probe). The problem I see and I cannot troubleshoot on my own is that the printer behaves as I expect when I home the axis individually (first X, then Y and finally Z) but not when I press the home all button on the dashboard. See the video to check it out.
      I know I have to edit all files individually and so I did. here they are:
      homeall.g
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Mar 28 2020 22:27:48 GMT+0100 (Central European Standard Time)
      G91 				; relative positioning
      G1 S2 X0.2 Y0.2 Z0.2 		; Move all axis 0.2 mm, clear stall status
      G29 S2 				; to clear the height map before Z homing
      M561			        ; reset bed compensation
      ; X and Y Sensorless homing
      M400 				; make sure everything has stopped before we make changes
      M913 X60 Y75 			; XY motors % current
      M915 X S2 Y S3 R0 F0 		; set X and Y sensitivity, do nothing when stall, unfiltered
      M574 X1 Y1 S3 			; set endstops to use motor stall
      G1 S2 Z5 F1200 			; lift Z
      G1 S1 X-220 Y-220 F3600 	; move X and Y back, stopping at the end stop
      M913 X100 Y100 			; XY motors to 100% current
      M915 X S30 Y S30 R0 F0 		; set X and Y sensitivity high, do nothing when stall, unfiltered
      ; Home Z with the probe
      G90 				; back to absolute mode
      G1 X110 Y110 S2 F3600 		; go to first bed probe point and home Z
      G30 				; home Z by probing the bed
      homex.g
      ; homex.g
      ; called to home the X axis
      G91			; set relative mode
      G1 S2 X0.2              ; Move X by 0.2 mm, clear stall status
      M561                     ;reset bed compensation
      M913 X60 		; X motor % current
      M915 X S2 R0 F0 	; set X sensitivity, do nothing when stall, unfiltered
      M574 X1 S3 		; set endstops to use motor stall
      G1 S1 X-220 F3600 	; move X back, stopping at the end stop
      M913 X100 		; XY motors to 100% current
      M915 X S30 R0 F0 	; set X sensitivity high, do nothing when stall, unfiltered
      G1 S2 Z-5 F1200         ; reset Z
      G90                     ; Absolute positioning
      homey.g
      ; homey.g
      ; called to home the Y axis
      G1 S2 Y0.2              ; Move Y by 0.2 mm, clear stall status
      M913 Y75 		; Y motor % current
      M915 Y S3 R0 F0 	; set X sensitivity, do nothing when stall, unfiltered
      M574 Y S3 		; set endstops to use motor stall
      G1 S1 Y-220 F3600 	; move X back, stopping at the end stop
      M913 Y100 		; XY motors to 100% current
      M915 Y S30 R0 F0 	; set Y sensitivity high, pause when stall, filtered
      G1 S2 Z-5 F1200         ; reset z
      homez.g
      ; homez.g
      ; called to home the Z axis
      G1 H2 Z5 F6000   	 ; lift Z relative to current position
      G90              	 ; absolute positioning
      G1 X110 Y110 F6000 	 ; go to first probe point
      G1 Z5 F100      ; lift Z relative to current position
      on my config.g I have something like this:
      M574 X Y S3 		; set endstops to use motor stall
      M915 X Y S30 R0 F0 	; set X sensitivity, do nothing when stall, unfiltered
      Any help on troubleshooting this, would be much appreciate it, as I don't feel like installing endstops... 🙂
      • droftarts
        droftarts administrators @FelixH last edited by
        @FelixH said in Sensorless homing tuning on cartesian printer:
        This line doesn't look right to me. Try splitting it out into two lines, like from your homex.g and homey.g files. I can't test this at the moment so just a theory.
        • FelixH
          I tried that, but to no avail... in order to print, this evening I had to lower the sensitivity on the homeall.g file, but then it doesn't home on the home position
            If homeX homeY and homeZ all work correctly on their own, why not change homeall to simply call each one of them in turn with M98.
            M98 Phomex.g
            M98 Phomey.g
            M98 Phomez.g
            I'm going to speculate that the electrical properties of the system as altered sufficiently when moving multiple motors at the same time that it isn't behaving as expected.
            Stall detection for homing is tricky. Personally, I'd run the wires and use a switch.
            FelixH 1 Reply Last reply Reply Quote 0
            • FelixH
              FelixH @Phaedrux last edited by
              @Phaedrux I though about your solution, but I didn‘t know how to implement it. I will try that and, if it doesn‘t work, I will run the wires...
              • FelixH
                Well, I just tried and it did the trick... a bit annoying seeing the Z axis moving up and down more than necessary, but for now I'll call it good...
                Any other speculation as for it didn't work would be educationally welcomed...
                • mendenmh
                  mendenmh last edited by
                  When I tried this command, it always stopped when one or the other axis hit a stop, unlike the case with switched homing where it lets each axis stop independently. I think the stall detection interrupts all axes. The independent homes seem to be the right solution. I went back to the switches anyways, just because I already had them installed.
                  • FelixH
                    FelixH last edited by FelixH
                    @mendenmh said in Sensorless homing tuning on cartesian printer:
                    I think the stall detection interrupts all axes...
                    Maybe that's the issue...
                    I'll try to edit the old homeall.g to do it individually, adding M400 all over the place.
                    • FelixH
                      Well, i mixed the code on the 3 independent homing files into one homeall.g file (see below). It appears to work without any issues...
                      I hope this post helps somebody else with similar issues.
                      Thanks a lot, everyone.
                      ; homeall.g
                      ;M98 Phomex.g
                      ;M98 Phomey.g
                      ;M98 Phomez.g
                      ; homex.g
                      M400; 			; make sure everything has stopped
                      ; homey.g
                      homez.g
