    Unsolved Unexpected behaviour in G32 dual Z bed levelling
    • OwenD
      OwenD last edited by
      I have set up dual independent Z axis motors and decided to redo my bed.g to use conditional G code.
      I had hoped to share the bed.g file as it should work for any Cartesian with dual Z axis.
      During the process I notice that when moving from the first probe point to the second, I am seeing movement of the Y axis which equates to the Y offset value set in G31
      I tested this by changing the offset to zero and the movement stopped.
      Board: Duet WiFi 1.02 or later
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-RC5 (2020-03-27b3)
      Duet WiFi Server Version: 1.23
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sat Jan 04 2020 09:46:45 GMT+1000 (Australian Eastern Standard Time)
      G90                                                             ; send absolute coordinates...
      M83                                                             ; ...but relative extruder moves
      M550 P"Flsun_I3_Duet"                                                ; set printer name
      M552 S1                                                         ; enable network
      M586 P0 S1                                                      ; enable HTTP
      M586 P1 S1                                                      ; enable FTP
      M586 P2 S0                                                      ; disable Telnet
      M569 P0 S1                                                      ; physical drive 0 goes forwards
      M569 P1 S0                                                      ; physical drive 1 goes backwards
      M569 P2 S1                                                      ; physical drive 2 goes forwards
      M569 P3 S1                                                      ; physical drive 3 goes forwards
      ;M584 X0 Y1 Z2 E3                                                ; set drive mapping
      M584 X0 Y1 Z2:4 E3												; two Z motors connected to driver outputs Z and E1
      M671 X-65:255 Y90:90 S5.5 										; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M350 X16 Y16 Z16 I1                           					; Configure microstepping with interpolation for XYZ
      M350 E16 I1														; Configure microstepping with interpolation for E0
      M92 X100.00 Y100.00 Z400.00                            			; set steps per mm XYZ
      M92 E1866 														; Set steps per mm for E0 zesty
      M566 X800.00 Y800.00 Z40.00 E40.00                            ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z1200.00 E6000.00                      ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z100.00 E120.00                         	; set accelerations (mm/s^2)
      M906 X1275 Y1275 Z1300 E450 I30                                ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                         ; Set idle timeout
      ;M208 X0 Y-6 Z0 S1                                               ; set axis minima
      M208 X0:200 Y-6:194 											; X carriage moves from -5 to 205, Y bed goes from 0 to 200
      M574 X1 S1 P"xstop"                                             ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                             ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                                      ; configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater3"                                               ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H3 F40 T6000 A8 S0.03 R0.5 B1                  ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X30 Y-5 Z1.06                                       ; set Z probe trigger value, offset and trigger height
      M557 X35:185 Y20:160 S20                                        ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" B4725 C7.06e-8         ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                           ; create bed heater output on bedheat and map it to sensor 0
      M143 H0 S130                                                    ; set temperature limit for heater 0 to 120C
      M307 H0 B0 S0.3                                                ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" B4725 C7.06e-8          ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                            ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S280                                                    ; set temperature limit for heater 1 to 280C
      M307 H1 B0 S1.0                                                ; disable bang-bang mode for the nozzle heater and set PWM limit
      M950 F0 C"fan0" Q500                                            ; create fan 0 on pin fan0 and set its frequency
      M106 P0 C"Part_Fan" S0 B2.0 H-1                                        ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                            ; create fan 1 on pin fan1 and set its frequency
      M106 P1 C"E0_Fan" S1 H1 B2.0 T45:55                           ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                                            ; create fan 2 on pin fan2 and set its frequency
      M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board" ; Configure MCU sensor
      M106 P2 C"Controller_Fan" H2 L0.2 X0.5 B1.2  T38:46    ; set fan 2 value, turn on at 50% if the CPU temperature reaches 40C, and increase to full speed gradually as the temperature rises to 46C
      ; Calibrate MCU temp
      M912 P0 S-4
      ; Set PID autotune parameters
      M307 H0 A94.1 C310.3 D14.7 S0.60 V24.0 B0
      ;M307 H1 A294.1 C170.0 D3.7 S0.70 V24.0 B0
      M307 H1 A333.6 C134.3 D10 S0.70 V24.0 B0
      M563 P0 S"Extruder1" D0 H1 F0                                   ; define tool 0
      G10 P0 X0 Y0 Z0                                                 ; set tool 0 axis offsets
      G10 P0 R0 S0                                                    ; set initial tool 0 active and standby temperatures to 0C
      ; Custom settings
      ;M592 D0 A0.012 B0                                             ; Set non linear extrusion
      M207 S1.8 F1800 T1800 Z0.1                                      ; Set retraction
      ;M593 F25                                                        ; cancel ringing at 25Hz
      M200 D1.75                                                      ; set all extruder filament diameters to 1.75mm
      G29 S1                                                          ; Load previously set bed map
      M376 H4                                                        ; set bed compensation taper (H10 means taper over 10mm)
      ;T0                                                              ; select first tool
      ;play startup tune
      G4 S6
      M98 P"0:/macros/songs/itchyscratchy.g"
      On a side note, I ran into the max G Code line length when calculating the mid point of the mesh. (The S2 did it)
      Hence I used the current position for the second probe point. Can't wait for variables 😉
      bed.g
      ; bed.g
      ; requires two independent Z lead screw motors to be configured
      ; https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
      ; uses conditional G Code for portability (requires Reprap Firmware version 3 or higher)
      ; Z Mesh probe area must be properly defined in M557 https://duet3d.dozuki.com/Wiki/Gcode#Section_M557_Set_Z_probe_point_or_define_probing_grid
      ; Note: The maximum amount of correction possible is defined in M671 (S parameter) https://duet3d.dozuki.com/Wiki/Gcode#Section_M671_Define_positions_of_Z_leadscrews_or_bed_levelling_screws
      ; If the printer hasn't been homed, home it
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
        G28
      ; Probe the bed and do auto leveling
      while true
        if iterations = 5
          abort "Too many auto calibration attempts"
        ;probe at XMin mesh probe point and midway of Y mesh area
        G30 P0 X{move.compensation.probeGrid.xMin} Y{((move.compensation.probeGrid.yMax-move.compensation.probeGrid.yMin)/2)+move.compensation.probeGrid.yMin} Z-99999
        if result != 0
          continue
        ;probe at X Max mesh probe point and midway of Y mesh area
        G30 P1 X{move.compensation.probeGrid.xMax} Y{move.axes[1].machinePosition} Z-99999 S2
        if result != 0
          continue
        ;set maximum probe deviation allowed between the two points
        if (move.calibration.initial.deviation <= 0.02)
          break
        ; if deviation between the two points is too high, repeat the test after Z axis has been adjusted.
        echo "Repeating calibration because deviation is too high " ^ move.calibration.initial.deviation ^ "mm"
      ; end loop
      G28	Z; Probe Z again just to be sure
      G29 S1 ; Reload bed compensation mesh
      OwenD 1 Reply Last reply Reply Quote 0
      • OwenD
        OwenD @OwenD last edited by
        @OwenD I've done a video to demonstrate this behavior.
        The black line on the tape was done by holding a pen on the bed and performing moves in the X axis.
        My Probe offsets are X30 Y-5
        You can see that when the G32 is performed, first it homes all (this is in bed.g
        Then when moving to the first probe point the bed actually moves 5mm in the Y direction.
        Then when it moves to the second probe point it moves and additional 5mm in the Y direction.
        It's not like this is giving me grief, I just don't understand why it is doing that.
        The maths for both the homeall and bed.g positions are identical (for Y direction)
        Video link
        ; bed.g
          G28
        while true
          if iterations = 5
          if result != 0
            continue
          if result != 0
            continue
            break
        ; end loop
        G28; Home all again just to be sure
        ; homeall.g
        ; called to home all axes
        G1 H2 Z5 F6000          ; lift Z relative to current position
        G1 H1 X-205 Y-205 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
        G1 H2 X5 Y5 F6000       ; go back a few mm
        G1 H1 X-205 Y-205 F360  ; move slowly to X and Y axis endstops once more (second pass)
        G1 H2 X{(move.compensation.probeGrid.xMax/2) - sensors.probes[0].offsets[0]} F6000
        G1 H2 Y{(move.compensation.probeGrid.yMax - move.compensation.probeGrid.yMin)/2 + move.compensation.probeGrid.yMin} F6000
        G30                     ; home Z by probing the bed
        • droftarts
          droftarts administrators @OwenD last edited by
          @OwenD I think you need someone with better understanding of the intricacies of the new conditional gcode and object model than me, but it feels like you're using a different Y coordinate with this line compared to the first line:
          And that the Y coordinate system in that line is using the probe offset. But I really don't know!
          • OwenD
            OwenD @droftarts last edited by
            @droftarts I couldn't use the exact same calculation on the second line because it hit the limit for max length of a gcode in a single line, however "current position" is the position of the first probe, so returns the same value.
            For the same reason I had to move to X and Y independently in homeall.g
            Not ideal, but necessary for now.
            Aside from that the first probe point moves to a different Y position to the homeall.g yet they use the same code.
            There is quite likely something I'm not understanding in the way the two processes are calculated, but it's odd. 🤔
