    Uneven/bulging layers
    • spettundefined
      spett
      Getting uneven layers/bulging layers printing with PLA (not tried anything other). Vasemode gies perfect prints.
      I'm little lost here, could it be because of long bowden tube? (~1meter) Do I need more cooling? I do have two 40mm fans directed on the model.
      Any suggestions is greatly appreciated!
      I have a DIY printer with kraken hotend and titan extruders controlled by duet ethernet. The frame is a very sturdy milled alu frame and all axes have THK square linear rails.
      • timcurtis67undefined
        timcurtis67
        Vase mode prints in one direction only. Regular prints move the head in both directions. Which is why you see issues when printing regular prints.
        I would say this is a backlash type mechanical issue. Check for loose pulleys, belts, ect.
        Could also need to be tuned with pressure advance to compensate for the long bowden tube.
