    RepRapFirmware 3.01-RC6 released
    Beta Firmware
    27
    165
    12.7k
      I've just released this at https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC6. New matching releases of Duet Software Framework (for Duet3/SBC setups) and Duet Web Control are also available. The release notes are at https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md.
      garyd9undefined 1 Reply Last reply Reply Quote 1
      • A Former User?
        A Former User
        Will future DWC releases like 2.1.0 retain full support for RRF2? At least until RRF3 goes mainstream perhaps? Couldn't see anything about compatibility except for 2.0.3 stated supporting 0.6/0.8.5 boards
        • tobias_munichundefined
          tobias_munich
          have issues after updating the SBC version. DWC, DCS and RRF
          seem DWC/DCS has problems connecting the DUET3 Board.
          SD-Only version has no problem
          Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
          Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
          Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
          chrishammundefined A Former User? elliott.griffithsundefined 3 Replies Last reply Reply Quote 0
          • chrishammundefined
            chrishamm administrators @tobias_munich
            @tobias_munich Please make sure you are on the unstable package feed, DSF 1.3 is not on the stable (default) package feed yet. To check, have a look at /etc/apt/sources.list.d/duet3d.list and make sure you have unstable instead of stable in there.
            @bearer DWC 2.1.0 remains compatible with previous firmware versions but be aware that I have not tested everything in depth with RRF2.
            Duet software engineer
            Dougal1957undefined A Former User? 2 Replies Last reply Reply Quote 0
            • A Former User?
              A Former User @tobias_munich
              @tobias_munich said in RepRapFirmware 3.01-RC6 released:
              verify the ribbon cable connecting the Duet and the SBC is installed correctly.
              verify the SPI drivers are loades ( ls /dev/spi*)
              check the logs for DCS (service duetcontrolserver status)
              edit: also, which SBC?
              tobias_munichundefined 1 Reply Last reply Reply Quote 0
                tobias_munich @A Former User
                @bearer it has run for weeks now. its not a new installation. will go deeper to understand the issue...
                  RRF 3.01-RC6 is NOT compatible to DSF 1.2.x. If you want to give it a try, make sure you are on the unstable branch and if you can, do NOT upgrade the firmware manually. The provided reprapfirmware package updates it automatically.
                  • A Former User?
                    @tobias_munich DWC is running otherwise you'd not get a web page, so issue is with DCS, logs are likely most relevant, checking the SPI drivers are just to dot the t's in case something external to the duet packages got updated to cause an issue
                      tobias_munich @chrishamm
                      @chrishamm seems that's my problem. will fix it..
                      • Dougal1957undefined
                        Dougal1957 @chrishamm
                        @chrishamm Chris I have upgraded mine to 1.3 of DSF but when attempting to upgrade to RC6 I get a failure due to no IAP file
                        Any advise
                        	M122
                        RepRapFirmware for Duet 3 MB6HC version 3.01-RC5 running on Duet 3 MB6HC v0.6 or 1.0
                        Board ID: 08DGM-9T66A-G63SJ-6J1DA-3SD6R-TV0BA
                        Used output buffers: 1 of 40 (5 max)
                        Static ram: 154084
                        Dynamic ram: 160892 of which 52 recycled
                        Exception stack ram used: 216
                        Never used ram: 77972
                        Tasks: NETWORK(ready,2076) HEAT(blocked,1196) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,216) MAIN(running,4956) IDLE(ready,80)
                        Owned mutexes:
                        Last reset 124:09:52 ago, cause: software
                        Last software reset at 2020-03-03 18:27, reason: User, spinning module LinuxInterface, available RAM 79528 bytes (slot 3)
                        Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
                        Error status: 0
                        Free file entries: 10
                        MCU temperature: min 38.4, current 41.6, max 43.2
                        Supply voltage: min 23.6, current 23.7, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
                        12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
                        Driver 0: standstill, reads 1090, writes 14 timeouts 0, SG min/max 0/0
                        Driver 1: standstill, reads 1090, writes 14 timeouts 0, SG min/max 0/0
                        Driver 2: standstill, reads 1091, writes 14 timeouts 0, SG min/max 0/0
                        Driver 3: standstill, reads 1091, writes 14 timeouts 0, SG min/max 0/0
                        Driver 4: standstill, reads 1092, writes 14 timeouts 0, SG min/max 0/0
                        Driver 5: standstill, reads 1092, writes 14 timeouts 0, SG min/max 0/0
                        Date/time: 2020-04-03 13:26:07
                        Slowest loop: 2.33ms; fastest: 0.14ms
                        Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
                        === MainDDARing ===
                        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                        === AuxDDARing ===
                        Segments left: 0
                        Movement lock held by null
                        HTTP* is ready with "M122" in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        SBC is idle in state(s) 0
                        Daemon* is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 0.80ms; fastest: 0.01ms
                        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                        HTTP sessions: 0 of 8
                        - Ethernet -
                        State: disabled
                        Error counts: 0 0 0 0 0
                        === CAN ===
                        Messages sent 1787965, longest wait 0ms for type 0
                        === Linux interface ===
                        State: 0, failed transfers: 2
                        Last transfer: 16ms ago
                        RX/TX seq numbers: 36774/40855
                        SPI underruns 3, overruns 3
                        Number of disconnects: 1
                        Buffer RX/TX: 0/0-0
                        === Duet Control Server ===
                        Duet Control Server v1.3.0.0
                        Code buffer space: 4096
                        Configured SPI speed: 8000000 Hz
                        Full transfers per second: 32.88
                        Doug
                        dc42undefined chrishammundefined 2 Replies Last reply Reply Quote 0
                          dc42 administrators @A Former User
                          @bearer said in ReprapFirmware 3.01-RC6 released:
                          That's unlikely. Future versions of DWC will provide features (e.g. the object cancellation interface) that are not supported by RRF2.
                          I expect RRF 3 to go "mainstream" shortly after RRF 3.01 stable is released. That release may be as little as a week away.
                            dc42 administrators @Dougal1957
                            @Dougal1957 said in RepRapFirmware 3.01-RC6 released:
                            That file should be included in the DSF release. I can provide it if necessary.
                            Dougal1957undefined 1 Reply Last reply Reply Quote 0
                              Dougal1957 @dc42
                              @dc42 please but it definitly fails and I have tried to do the Sudo Apt-get Update sequence twice as well I have appended the M122 log to my post above.
                              I will probably need simple instruction on what to do with the file mind.
                              Doug
                                chrishamm administrators @Dougal1957
                                @Dougal1957 Sorry, looks like like this file was missing in the RRF package, I've just added it back and uploaded it to another location: http://pkg.duet3d.com/Duet3iap_spi_MB6HC.bin You may need to rename it to Duet3iap_spi.bin.
                                • A Former User?
                                  A Former User
                                  if the issue is stable/unstable package feed run grep duet3d -r /etc/aptto check and echo "deb https://pkg.duet3d.com/ unstable armv7" | sudo tee /etc/apt/sources.list.d/duet3d-unstable.listto fix if needed.
                                  or what that guy said ☝
                                  • chas2706undefined
                                    chas2706
                                    You M112 suggests you are running 3.01-RC5.
                                    • A Former User?
                                      A Former User @chrishamm
                                      @chrishamm said in RepRapFirmware 3.01-RC6 released:
                                      btw that conflicts with the wiki that says to create another file duet3d-unstable.list
                                        Dougal1957 @chas2706
                                        @chas2706 exactly the point the upgrade to rc6 is failing
                                          Dougal1957 @A Former User
                                          @bearer Defo on the Unstable branch
                                          pi@duet3:~ $ grep duet3d -r /etc/apt
                                          /etc/apt/sources.list.d/duet3d.list:deb https://pkg.duet3d.com/ stable armv7
                                          /etc/apt/sources.list.d/duet3d-unstable.list:deb https://pkg.duet3d.com/ unstable armv7
                                          Binary file /etc/apt/trusted.gpg.d/duet3d.gpg matches
                                          pi@duet3:~ $ echo "deb https://pkg.duet3d.com/ unstable armv7" | sudo tee /etc/apt/sources.list.d/duet3d-unstable.list
                                          pi@duet3:~ $ sudo apt-get update
                                          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                          Hit:3 https://pkg.duet3d.com unstable InRelease
                                          Hit:4 https://pkg.duet3d.com stable InRelease
                                          Reading package lists... Done
                                          pi@duet3:~ $
                                          Doug
                                          A Former User? chrishammundefined 2 Replies Last reply Reply Quote 0
                                          • A Former User?
                                            A Former User @Dougal1957
                                            yeah
                                            do wget http://pkg.duet3d.com/Duet3iap_spi_MB6HC.bin -O /opt/dsf/sd/sys/Duet3iap_spi.bin
