    Quick LED PSU question
    107
    • aniron
      aniron last edited by
      Hi, not strictly Duet related but hopefully someone can help.
      My printer was originally a Ormerod 2 with a 200W Meanwell PSU.
      This had a wire connecting the negative output with mains ground.
      My new Meanwell PSU has the mains connections at one end and the 12V connections at the other.
      Should I connect mains ground on the PSU with the negative connector on the 12V side and thus the Duet (0.6) ground?
      My printer isn't hooked up to a mains outlet with ground, if it matters.
      A Former User 1 Reply Last reply Reply Quote 0
      • A Former User
        A Former User @aniron last edited by
        @aniron said in Quick LED PSU question:
        then neither does connecting anything else to the mains protected earth; if you did have outlets with PE then its still a can of worms, but as you don't we might as well not go there.
        aniron 1 Reply Last reply Reply Quote 0
        • aniron
          aniron @Guest last edited by
          @bearer
          yeah, but A)
          I might plug the printer into such a socket in the future.
          and B)
          I might want to use the old 200W PSU for some other purpose in the future, and it would be nice to know if the GND-negative wire should be retained or removed.
          • A Former User
            A Former User last edited by
            the (short) answer is Duet (dc42) recommends doing it, but its not a black and white situation.
            https://forum.duet3d.com/post/48107
            • aniron
              @bearer what are the drawbacks of doing it?
              • A Former User
                i do believe one was mentioned in the post linked to, the other reasons are mostly tolls on forums https://forum.duet3d.com/search?term=ground&in=titles
                  dc42 administrators @aniron last edited by
                  The only drawback I am aware if is that if you connect the Duet to a PC via the USB cable, you will have a ground loop. Normally this doesn't cause any trouble but it can do under two different types of fault condition: (a) a bad connection between PSU negative output and Duet VNI negative input; or (b) powering the PC and the Duet from different sockets, and there is a large difference in ground potential between the two sockets. See https://duet3d.dozuki.com/Wiki/USB_ground_loops.
                  • Danal
                    Danal last edited by
                    There is no absolutely right or wrong answer to "connect circuit ground to earth ground" on Printers and CNC and other motion controlled machines.
                    I do help a lot of people get the glitches out of their CNC, and I can tell you the policy I've developed over the years:
                    1. "Star ground" everything that needs a circuit ground. This is a long topic of its own... the shortest version is: Run a ground wire back to ONE central location for each ground; no chaining".
                    2. DO NOT connect circuit ground to Mains (earth, wall) ground. UNLESS the machine still glitches. Then, DO connect them.
                    How is that for "eat your cake and have it too"??
