    Switching a Fan Between On and Thermostatic
    fans thermostatic control
    • CCS86
      CCS86 last edited by
      Hi guys,
      I have a fan to cool my Maestro that is currently configured for thermostatic control with the following config lines:
      M308 S2 Y"drivers" A"DRIVERS"                          ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
      M308 S3 Y"mcu-temp" A"MCU"                             ; configure sensor 3 as thermistor on pin e1temp for left stepper
      M106 P2 H2:3 L1 X1 B0.3 T49                            ; set fan 2 value
      After turning up the stepper current, I found that MCU temp isn't a great analog for stepper driver temp. With MCU temp only a few degrees above "resting" temp, I was throwing stepper driver overheat warnings.
      My question is if I can keep thermostatic control as a default, and force the fan on full time during a print? Or, will turning the fan "on" overwrite the thermostatic control.
      I could always reassert the thermostatic config in my end gcode, and I guess it would have to go in my stop.g file as well.
      It would be even better if we could setup stepper driver as a true sensor, instead of just an overheat flag.
        Phaedrux Moderator @CCS86 last edited by
        @CCS86 said in Switching a Fan Between On and Thermostatic:
        This is what I do. You can also tie the fan speed to the bed and hotend temp so that when they are at temp (and likely printing) the board cooling fan will also be running.
        You can if you have an open thermistor port and attach a thermistor to the driver. However you'd have to choose one driver to monitor which may or may not be representative of the other drivers.
        In general the Maestro drivers run hotter than the Duet Wifi, and more cooling is required, so I think option 1 is probably the best way to go. More cooler is better than not enough cooling as electronics go.
        CCS86 1 Reply Last reply Reply Quote 2
        • CCS86
          CCS86 @Phaedrux last edited by
          @Phaedrux said in Switching a Fan Between On and Thermostatic:
          That's a good call on using bed and/or hotend temp!
          Can you define thermostatic trigger temps per sensor?
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
            I don't think so...
            • CCS86
              That's what I figured.
              I'll just set the temp trigger to ~52* for both hot end and MCU. That will make sure that the fan is on during any print and cooldown period, plus if it is idle and gets hot for some reason.
              Thanks!
