    FLSUN QQ-S-Pro config???
    1487
    • tjc2005
      tjc2005 last edited by tjc2005
      Hi all, I am new to this, I have bought a Duet 2 Wifi for my FLSUN-QQ-S-Pro and I have no idea how to configure the reprap firmware for it for my printer profile.
      Here are the original settings for the old board, robin mini v2.0
      robin_mini_config.txt
      I can't seem to translate this into what is needed. Can anyone give me the config I need to set up this printer?
      • PaulHew
        PaulHew last edited by
        @tjc2005 You need to use the RRF Config tool
        https://configtool.reprapfirmware.org/Start
        it is easy to follow.
        Make sure you take note of the speeds IIRC it is different to Marlin.
        If you need any further help, please post.
        First things first I would update the firmware to the latest RRF2 2.5.1 IIRC
        HTH
        Paul
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        • tjc2005
          yeah I am on that, but I have no idea what values to change, as they look different in the robinmini config file, the duet firmware is on 3.0 stable. I just need the printer profile working.
          I have found this from the flsun qqs facebook group that someone made, uploaded it to the SD, started duetwifi 192.168.1.XXX and it is there, but can't see the settings he's used to configure the printer, e.g. height etc
          config (1).g
          • PaulHew
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M665_Set_delta_configuration
            This tells you what the commands and parameters do.
            Its my bible and probably a lot of other peoples too!
            So this line is the one I think you are looking for
            M665 R142.45 L280.75 B130 H375.5 ; Set delta radius, diagonal rod length, printable radius and homed height
            And this is from the GCode manual
            Parameters
            Lnnn Diagonal rod length2
            Rnnn Delta radius
            Bnnn Safe printing radius
            Hnnn Nozzle height above the bed when homed after allowing for endstop corrections
            Xnnn X tower position correction1
            Ynnn Y tower position correction1
            Znnn Z tower position correction1
            Does that help?
            Regards,
            Paul
            • PaulHew
              Found this to while looking for something else
              https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
              Regards,
              Paul
              • tjc2005
                Thank you, someone else gave me their settings so I am going to try them out first, so hopefully I won't have to do much! thanks
                Meki 1 Reply Last reply Reply Quote 0
                • tjc2005
                  well that didn't work, or I have the wiring wrong. I don't understand how to configure the printer I must admit. Stuff like setting up printer radius only allows for 105mm etc but when I translate what I need for the duet from the mks robin it exceeds those size restrictions.
                  inolab 1 Reply Last reply Reply Quote 0
                  • inolab
                    inolab @tjc2005 last edited by
                    @tjc2005 said in FLSUN QQ-S-Pro config???:
                    Are you working in this project duet 2 wifi? do you have success?
                    tjc2005 1 Reply Last reply Reply Quote 0
                    • tjc2005
                      tjc2005 @inolab last edited by
                      @inolab said in FLSUN QQ-S-Pro config???:
                      no success. can't get probe working.
                      • Meki
                        Meki @tjc2005 last edited by
                        @tjc2005 could you share that config with me as well?
                        Blackfyre.ninja | Medium
                        • manpowre
                          manpowre last edited by manpowre
                          I know this is old, but I wanted to comment that I got the RR3.3b2 working with my duet 3d and the flsun qq-s pro.
                          I connected the probe to zbrobe.in and gnd (2 wires) with the following config.g command:
                          M558 P5 C"^zprobe.in" H10 F600 T6000
                          The z axis trigger height I use this:
                          G31 P25 X-2 Y-2 Z17.73
                          The z17.73 needs to be measured but this is what I got on my setup.
                          Also the diameters I use is this:
                          M665 R142.45 L280.75 B130 H373.35
                          M92 X100.63 Y99.48 Z99.3 E392
                          Now the H373.35 I fine tuned from my homing position slightly instead of 371 as in the robin firmware config.
                          After I turn printer on I do home the axis, then attach the probe and calibrate 2 times until I get close to 0.01 accuracy. Then I move the printer to start position and use the status page babystep to fine adjust with a paper before print. The probing is done with hotend off and bed on at 60 degrees.
