    help with conditions in variable g-code
    304
    • arhiundefined
      arhi
      I have this:
        G1 X110 Y-100 Z5 F9000
        M400
        G31 P{sensors.probes[0].value[0] + 8}
        G30 P4 X110 Y-100 Z-9999
        if result != 0
          echo "ERROR P4"
          continue
        echo "DONE P4"
      so nothing special, go, probe, if successful print done, if not print error ... simple enough but .. output:
      4/10/2020, 12:30:58 PM 	Error: Z probe already triggered at start of probing move
      DONE P4
      So G30 produced Error, RRF knows there's an error and yet the "result" is 0 ?! like the probing went ok ? (3.01RC6)
      What am I doing wrong?
        dc42 administrators @arhi
        @arhi said in help with conditions in variable g-code:
        What error did it report?
        arhiundefined 1 Reply Last reply Reply Quote 0
        • arhiundefined
          arhi @dc42
          @dc42 you see the error just before the DONE:
          • OwenDundefined
            OwenD
            I would say that the firmware, having sensed that the probe is already triggered is (correctly) bailing out of the procedure to head off any possible damage,
            • arhiundefined
              arhi @OwenD
              @OwenD that is ok, the movement behavior is ok, but the return value is 0 and 0 means "ok", not "error"
                It's a bug, which will be fixed in 3.01-RC7. Thanks for reporting it.
                arhiundefined 1 Reply Last reply Reply Quote 1
                • arhiundefined
                  arhi
                  Good, I'm not going crazy then 😄
                  • arhiundefined
                    arhi @dc42
                    @dc42 btw it returns zero in event of other error too (not triggered after a while)
                    • arhiundefined
                      arhi
                      Error: Probe points P0 to P3 must be in clockwise order starting near minimum X and Y, and P4 must be near the centre
                      this error does not return 0 (after doing G30 P24 X110 Y100 Z-9999 S0 all the other ones were without S parameter)
