    Pushing limits - Duet controlled Cetusd3D
    • fotomasundefined
      fotomas
      I have upgraded my duet-controlled Cetud3d with a Hemera extruder. I have been testing how fast it can print and still have not reached its limits.
      Peak speed in the PLA print below is about 250 mm/s , reported by DWC.
      • Lauyerheight 0.20 mm
      • Print time 40 minutes.
      • Acceleration set to 2500 mm/sec^2 (M201)
      • Allowable instantaneous speed change 800 (M566)
      This is unnecessary and so much FUN 😁
      https://youtu.be/gCN8IdGvwas
        Not bad for a cantilevered X bed flinger!
        Could probably cut that time down even further with a linear infill pattern.
        What's your pressure advance at?
        fotomasundefined 1 Reply Last reply Reply Quote 0
        • fotomasundefined
          fotomas @Phaedrux
          @Phaedrux None - not using pressure advance. Have tried it but it brought more trouble than benefit.
            I think it would probably improve the rounded corners a bit at that speed.
