    What is wrong with my infill?
    • AdrAs
      AdrAs last edited by
      Ok, I give up, I just can't figure it out why my infill is so broken. I hope you guys can help
      I'm printing china PETG (brand new high end PETG has the same effects). With an anycubic Predator with a Mosquito hotend and a Bondtech extruder. Outer Perimeters and solid infill no problem at speeds up to 100mm/s, I already reduced the infill speed to 40mm/s so I doubt it's the extruder.
      Here's my duet config:
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time)
      G90                                         				; Send absolute coordinates...
      M83                                         				; ...but relative extruder moves
      M550 PPredator        ; Set machine name
      M552 S1        ; Enable network
      M586 P0 S1        ; Enable HTTP
      M586 P1 S0        ; Disable FTP
      M586 P2 S0        ; Disable Telnet
      ; Delta Settings
      ; default B was 185
      ;Height changed due to new hotend
      ;M665 L440.000 R227 H456.0 B185 						 	; Set delta radius, diagonal rod length, printable radius and homed height
      M665 L440.000 R227 H422.5 B185 						 	; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 A0.00 B0.00               			     	; Put your endstop adjustments here, or let auto calibration find them
      M552 P0.0.0.0 S1  	                        				; Enable network and acquire dynamic address via DHCP
      M569 P0 S1                                  				; Drive 0 goes forwards
      M569 P1 S1                                  				; Drive 1 goes forwards
      M569 P2 S1                                  				; Drive 2 goes forwards
      M569 P3 S1                                  				; Drive 3 goes forwards
      M350 X16 Y16 Z16 E16 I1                     				; Configure microstepping with interpolation
      ;M92 X80.00 Y80.00 Z80.00 E380.45             				; Set steps per mm
      ; Updated E for Bondtech Extruder
      M92 X80.00 Y80.00 Z80.00 E415             				; Set steps per mm
      M566 X1000 Y1000 Z1000 E1000    	            			; Set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z12000.00 E10000 				; Set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z3000.00 E3000.00    				; Set accelerations (mm/s^2)
      M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I30 				; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                                     				; Set idle timeout
      ; Retraction
      ;M207 S4.0 F5000 R-0.025 T2500 Z0.5							; Firmware retraction
      M208 Z-0.4 S1                                  				; Set minimum Z - WARNING, possibly too low, but only setting a minus value allows the printer to baby step below ZERO-Z position
      M574 X2 Y2 Z2 S1                            				; Set active high endstops
      ; F Dive speed in mm/sec default 120
      ; T Probe Speed in mm/sec default 6000
      ; Very slow settings for testing: F=20 T=600
      ; H Dive height default 3
      M558 P5 H2 F120 T6000 L1                      				; Set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z16.0                      				; Set Z probe trigger value, offset and trigger height
      M557 R185 S70                               				; Define mesh grid
      G29 S1									; Load the heightmap
      M307 H0 A137.8 C533.3 D1.5 V24.3 B0                       		; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4300 C0 R4700                 				; Set thermistor + ADC parameters for heater 0
      M143 H0 S120                                				; Set temperature limit for heater 0 to 120C
      ; Default china sensor
      ;M305 P1 T100000 B4300 C0 R4700                 				; Set thermistor + ADC parameters for heater 1
      ; Mosquito Temperature sensor
      M305 P1 B3800 T500000 R4700						; Set thermistor + ADC parameters for heater 1 - Mosquito temperature sensor
      M143 H1 S450                                				; Set temperature limit for heater 1 to 450C
      M106 P0 S0 I0 F500 H-1                    				; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      ; Currently not connected fan below
      ;M106 P1 S1 I0 F500 H1 T45                   				; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S.5 I0 F18000 H1 T45 B1						; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1                               				; Define tool 0
      G10 P0 X0 Y0 Z0                             				; Set tool 0 axis offsets
      G10 P0 R0 S0                                				; Set initial tool 0 active and standby temperatures to 0C
      M572 D0 S0.1												; Pressure Advance
      ;M591 D0 P2 C4 S1											; Activate filament sensor
      M404 N1.75 												; Set for print monitor
      ; Disabled, not sure what it does
      ;M592 D0 A0.07772 B-0.00029 									; Nonlinear extrusion. Set parameters for extruder drive 0
      M501                                               			; Load saved parameters from non-volatile memory
      • AdrAs
        And here's my Slicer PE config
        # generated by PrusaSlicer 2.2.0+win64 on 2020-04-14 at 11:19:04 UTC
        avoid_crossing_perimeters = 0
        bed_custom_model =
        bed_custom_texture =
        bed_shape = 186.787x16.3417,184.651x32.559,181.111x48.5286,176.192x64.1288,169.933x79.2409,162.38x93.75,153.591x107.546,143.633x120.523,132.583x132.583,120.523x143.633,107.546x153.591,93.75x162.38,79.2409x169.933,64.1288x176.192,48.5286x181.111,32.559x184.651,16.3417x186.787,1.14811e-14x187.5,-16.3417x186.787,-32.559x184.651,-48.5286x181.111,-64.1288x176.192,-79.2409x169.933,-93.75x162.38,-107.546x153.591,-120.523x143.633,-132.583x132.583,-143.633x120.523,-153.591x107.546,-162.38x93.75,-169.933x79.2409,-176.192x64.1288,-181.111x48.5286,-184.651x32.559,-186.787x16.3417,-187.5x2.29621e-14,-186.787x-16.3417,-184.651x-32.559,-181.111x-48.5286,-176.192x-64.1288,-169.933x-79.2409,-162.38x-93.75,-153.591x-107.546,-143.633x-120.523,-132.583x-132.583,-120.523x-143.633,-107.546x-153.591,-93.75x-162.38,-79.2409x-169.933,-64.1288x-176.192,-48.5286x-181.111,-32.559x-184.651,-16.3417x-186.787,-3.44432e-14x-187.5,16.3417x-186.787,32.559x-184.651,48.5286x-181.111,64.1288x-176.192,79.2409x-169.933,93.75x-162.38,107.546x-153.591,120.523x-143.633,132.583x-132.583,143.633x-120.523,153.591x-107.546,162.38x-93.75,169.933x-79.2409,176.192x-64.1288,181.111x-48.5286,184.651x-32.559,186.787x-16.3417,187.5x-4.59243e-14
        bed_temperature = 65
        before_layer_gcode =
        between_objects_gcode =
        bottom_fill_pattern = rectilinear
        bottom_solid_layers = 3
        bottom_solid_min_thickness = 0
        bridge_acceleration = 0
        bridge_angle = 0
        bridge_fan_speed = 100
        bridge_flow_ratio = 1
        bridge_speed = 80
        brim_width = 0
        clip_multipart_objects = 1
        colorprint_heights =
        complete_objects = 0
        cooling = 1
        cooling_tube_length = 5
        cooling_tube_retraction = 91.5
        default_acceleration = 0
        default_filament_profile = ""
        default_print_profile =
        deretract_speed = 0
        disable_fan_first_layers = 2
        dont_support_bridges = 1
        draft_shield = 0
        duplicate_distance = 6
        elefant_foot_compensation = 0
        end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament\n"
        end_gcode = M104 S0 ; turn off temperature\nG28 X0  ; home X axis\nM84     ; disable motors\n
        ensure_vertical_shell_thickness = 0
        external_perimeter_extrusion_width = 0.4
        external_perimeter_speed = 80
        external_perimeters_first = 0
        extra_loading_move = -2
        extra_perimeters = 1
        extruder_clearance_height = 20
        extruder_clearance_radius = 20
        extruder_colour = ""
        extruder_offset = 0x0
        extrusion_axis = E
        extrusion_multiplier = 1
        fan_always_on = 1
        fan_below_layer_time = 30
        filament_colour = #29B2B2
        filament_cooling_final_speed = 3.4
        filament_cooling_initial_speed = 2.2
        filament_cooling_moves = 4
        filament_cost = 20
        filament_density = 1.38
        filament_deretract_speed = 40
        filament_diameter = 1.75
        filament_load_time = 0
        filament_loading_speed = 28
        filament_loading_speed_start = 3
        filament_max_volumetric_speed = 0
        filament_minimal_purge_on_wipe_tower = 15
        filament_notes = "Also PETG ist super flüssig, und neigt zum Fäden ziehen.\n\nTODO\n\nVersuchen mit möglichst niedriger Termperatur zu drucken um Stringing zu vermeiden\nRetraction speed soll langsam sein, 25 sind empfohlen\nMan soll auch ein wenig Abstand zwischen Druckkopf und Platte haben, anders als bei PLA\n"
        filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6"
        filament_retract_before_travel = nil
        filament_retract_before_wipe = nil
        filament_retract_layer_change = nil
        filament_retract_length = 1
        filament_retract_lift = nil
        filament_retract_lift_above = nil
        filament_retract_lift_below = nil
        filament_retract_restart_extra = nil
        filament_retract_speed = 40
        filament_settings_id = "Predator PETG"
        filament_soluble = 0
        filament_toolchange_delay = 0
        filament_type = PET
        filament_unload_time = 0
        filament_unloading_speed = 90
        filament_unloading_speed_start = 100
        filament_vendor = (Unknown)
        filament_wipe = nil
        fill_angle = 45
        fill_density = 10%
        first_layer_acceleration = 0
        first_layer_bed_temperature = 65
        first_layer_extrusion_width = 0.4
        first_layer_height = 0.2
        first_layer_speed = 40
        first_layer_temperature = 240
        gap_fill_speed = 80
        gcode_comments = 1
        gcode_flavor = reprap
        gcode_label_objects = 0
        high_current_on_filament_swap = 0
        host_type = duet
        infill_acceleration = 0
        infill_every_layers = 1
        infill_extruder = 1
        infill_extrusion_width = 0.4
        infill_first = 0
        infill_only_where_needed = 0
        infill_overlap = 15%
        infill_speed = 40
        interface_shells = 0
        layer_gcode =
        layer_height = 0.2
        machine_max_acceleration_e = 10000,5000
        machine_max_acceleration_extruding = 1500,1250
        machine_max_acceleration_retracting = 1500,1250
        machine_max_acceleration_x = 9000,1000
        machine_max_acceleration_y = 9000,1000
        machine_max_acceleration_z = 500,200
        machine_max_feedrate_e = 120,120
        machine_max_feedrate_x = 500,200
        machine_max_feedrate_y = 500,200
        machine_max_feedrate_z = 12,12
        machine_max_jerk_e = 2.5,2.5
        machine_max_jerk_x = 10,10
        machine_max_jerk_y = 10,10
        machine_max_jerk_z = 0.2,0.4
        machine_min_extruding_rate = 0,0
        machine_min_travel_rate = 0,0
        max_fan_speed = 100
        max_layer_height = 0
        max_print_height = 450
        max_print_speed = 80
        min_fan_speed = 100
        min_layer_height = 0.07
        min_print_speed = 10
        min_skirt_length = 40
        notes =
        nozzle_diameter = 0.4
        only_retract_when_crossing_perimeters = 1
        ooze_prevention = 0
        output_filename_format = [input_filename_base].gcode
        overhangs = 1
        parking_pos_retraction = 92
        perimeter_acceleration = 0
        perimeter_extruder = 1
        perimeters = 4
        post_process =
        print_host = http://192.168.178.102/
        print_settings_id = Predator_Print_Testing
        printer_model =
        printer_notes =
        printer_settings_id = Predator_Printer
        printer_technology = FFF
        printer_variant =
        printer_vendor =
        printhost_apikey =
        printhost_cafile =
        raft_layers = 0
        remaining_times = 0
        resolution = 0
        retract_before_travel = 2
        retract_before_wipe = 0%
        retract_layer_change = 0
        retract_length = 2
        retract_length_toolchange = 10
        retract_lift = 0
        retract_lift_above = 0
        retract_lift_below = 0
        retract_restart_extra = 0
        retract_restart_extra_toolchange = 0
        retract_speed = 40
        seam_position = aligned
        serial_port =
        serial_speed = 250000
        silent_mode = 1
        single_extruder_multi_material = 0
        single_extruder_multi_material_priming = 1
        skirt_distance = 10
        skirt_height = 1
        skirts = 2
        slice_closing_radius = 0.049
        slowdown_below_layer_time = 15
        small_perimeter_speed = 80
        solid_infill_below_area = 70
        solid_infill_every_layers = 0
        solid_infill_extruder = 1
        solid_infill_extrusion_width = 0.4
        solid_infill_speed = 80
        spiral_vase = 0
        standby_temperature_delta = -5
        start_filament_gcode = "; Filament gcode\n"
        start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\n
        support_material = 1
        support_material_angle = 0
        support_material_auto = 1
        support_material_buildplate_only = 0
        support_material_contact_distance = 0.3
        support_material_enforce_layers = 0
        support_material_extruder = 1
        support_material_extrusion_width = 0.4
        support_material_interface_contact_loops = 0
        support_material_interface_extruder = 1
        support_material_interface_layers = 3
        support_material_interface_spacing = 0
        support_material_interface_speed = 100%
        support_material_pattern = rectilinear
        support_material_spacing = 3
        support_material_speed = 40
        support_material_synchronize_layers = 0
        support_material_threshold = 0
        support_material_with_sheath = 1
        support_material_xy_spacing = 50%
        temperature = 240
        thin_walls = 1
        threads = 16
        thumbnails =
        toolchange_gcode =
        top_fill_pattern = rectilinear
        top_infill_extrusion_width = 0.4
        top_solid_infill_speed = 80
        top_solid_layers = 3
        top_solid_min_thickness = 0
        travel_speed = 80
        use_firmware_retraction = 0
        use_relative_e_distances = 0
        use_volumetric_e = 0
        variable_layer_height = 1
        wipe = 0
        wipe_into_infill = 0
        wipe_into_objects = 0
        wipe_tower = 0
        wipe_tower_bridging = 10
        wipe_tower_no_sparse_layers = 0
        wipe_tower_rotation_angle = 0
        wipe_tower_width = 60
        wipe_tower_x = 180
        wipe_tower_y = 140
        wiping_volumes_extruders = 70,70
        wiping_volumes_matrix = 0
        xy_size_compensation = 0
        z_offset = 0
        peirof 1 Reply Last reply Reply Quote 0
        • peirof
          peirof @AdrAs last edited by
          @AdrAs have you try another slicer?
          • AdrAs
            Only Slic3r, with similar settings, same result
            • DocTrucker
              DocTrucker last edited by
              Go through e-steps and filament diameter calibration to get mavhine extruding actuately.
              Consider tuning linear/non linear extrusion correction.
              Ensure nozzle diameter is set right.
              Check extrusion width is set to around 105 -110% of nozzle diameter.
              Be aware that some infill uses bridging parameters.
              Make sure volumetric rates are in the right region foe the nozzle hotend combo. A v6 with a 0.4mm nozzle will do around 10mm3/sec.
              Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
              • AdrAs
                Well, seems like my perimeter overlap was so small, that the infill layer didn't properly connect and was "bridging" mid air. I increased the perimeter overlap and now the issue is gone ....
