Fan Control - Shows 8 Fans but i have only three connections
  • Hi,
    i just want to configure my new printer and the fan control shows up to 8 fans, but i have only the standard duet 2 wifi without an duex extension board.
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Apr 12 2020 21:12:30 GMT+0200 (Mitteleuropäische Sommerzeit)
    G90                                      ; send absolute coordinates...
    M83                                      ; ...but relative extruder moves
    M550 P"BLV AM8"                          ; set printer name
    M552 S1                                  ; enable network
    M586 P0 S1                               ; enable HTTP
    M586 P1 S0                               ; disable FTP
    M586 P2 S0                               ; disable Telnet
    M569 P0 S0                               ; physical drive 0 goes backwards
    M569 P1 S0                               ; physical drive 1 goes backwards
    M569 P2 S1                               ; physical drive 2 goes forwards
    M569 P3 S1                               ; physical drive 3 goes forwards
    M584 X0 Y1 Z2 E3                         ; set drive mapping
    M350 X16 Y16 Z16 E16 I1                  ; configure microstepping with interpolation
    M92 X80.456 Y80.6956 Z408.1451 E385.00   ; set steps per mm
    M566 X600.00 Y600.00 Z18.00 E300.00      ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E6000.00  ; set maximum speeds (mm/min)
    M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E1000 I50            ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                  ; Set idle timeout
    M208 X-33 Y-10 Z0 S1                     ; set axis minima
    M208 X220 Y220 Z240 S0                   ; set axis maxima
    M574 X1 Y1 S0                            ; set active low and disabled endstops
    M574 Z1 S2                               ; set endstops controlled by probe
    M307 H3 A-1 C-1 D-1			             ; Disable the 3th Heater to free up PWM channel 5 on the Duex board.
    M558 P9 H3 F120 T6000 A10 S0.003 B1 R0.5 ; set Z probe type to bltouch and the dive height + speeds
    G31 P25 X30.44 Y-9.48 Z0.7              ; set Z probe trigger value, offset and trigger height
    M557 X5:200 Y5:200 S20                   ; define mesh grid
    M307 H0 B0 S1.00                         ; disable bang-bang mode for the bed heater and set PWM limit
    M305 P0 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 0
    M143 H0 S130                             ; set temperature limit for heater 0 to 130C
    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
    M143 H1 S275                             ; set temperature limit for heater 1 to 275C
    M106 P0 S0 I0 F500 H-1                   ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H-1                   ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S1 I0 F500 H-1                   ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M563 P0 D0 H1 F0                         ; define tool 0
    G10 P0 X0 Y0 Z0                          ; set tool 0 axis offsets
    G10 P0 R0 S0                             ; set initial tool 0 active and standby temperatures to 0C
    ; BLTouch startup
    G4 S2					                 ; Pause a couple seconds
    M280 P64 S160				             ; Clear any alarms
    M402					                 ; retract pin just in case
    M912 P0 S3.4
    T0                                       ; select first tool
    Is my configuration wrong?
    Thanks for help 🙂
  • Moderator
    That only shows 3 fans configured.
    Where are you seeing 8 fans?
    What firmware and DWC version are you using?
  • Is visible on the Dashboard and also on the Status page under Fans
    Fan Control
    Duet Web Control 2.1.1
    Board: Duet WiFi 1.02
    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
    Duet WiFi Server Version: 1.23
  • @TiToMoskito said in Fan Control - Shows 8 Fans but i have only three connections:
    As a suggestion, go back to DWC2.07 to see if that fixes your problem and report back please.
    I am aware of some issues with 2.10 and 2.11.
    HTH
    Paul
  • Thanks that worked for me, downgrading solves it.
    Is the display correct using DWC 2.1.4 ?
