    plane leveling problems with Z IR probe
    • massimilianocontiundefined
      massimilianoconti
      hi I'm having problems with the duet wifi, all the fans have broken, and now I see problems with the leveling of the printing plate, through the Z IR probeESITO TEST IR.jpg
        droftarts administrators @massimilianoconti
        @massimilianoconti Please give us more details. See: https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
        Have you checked the fan fuse?
          massimilianoconti
          hello thanks for the reply. yes it is ok i think a mosfet is burned
            massimilianoconti
            I have tried many things from the black sheet under the glass to changes in the height of the probe to various config settings. or the probe is defective otherwise I have no other ideas. in this way you cannot print the nozzle hitting the glass by scratching
              massimilianoconti
              the printer is Cartesian 300x300x300 extruder e3d vulcano
                massimilianoconti
                motherboard duet wifi vers. 1.04
                Board: Duet WiFi 1.02 or later
                Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05 (2019-12-13b1)
                Duet WiFi Server Version: 1.23
