    Ender 5 Pro Hemera Bltouch upgrade to Duet Wifi Firmware 3
    2.1k
    • jumpedwithbothfeetundefined
      jumpedwithbothfeet @Daniel
      @Daniel the pins were assigned during the config build but I obviously had to re-pin the end stop plugs, you can also manually change the config file in DWC however I’m using the duet 3 board I’m not sure if you can configure/assign pins on the duet 2, I’m sure @Phaedrux would be able to confirm that.
      Glad to hear you want to create a guide for the ender 5 if I can help let me know 🙂
      Regards Jim
      6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
        Phaedrux Moderator @jumpedwithbothfeet
        @jumpedwithbothfeet said in Ender 5 Pro Hemera Bltouch upgrade to Duet Wifi Firmware 3:
        In RepRapFirmware 3 pins can be re-defined in software. That applies to Duet 3 and Duet 2 boards.
        Danielundefined 1 Reply Last reply Reply Quote 0
        • Danielundefined
          Daniel @Phaedrux
          @Phaedrux
          I have not posted in a while and I wanted to thank for all the help received, by posting the latest config for the machine.
          Best configuration (so far) working with Simplify 3D. Please uncheck the boxes as per this picture to let the firmware control the printing.
          The config is below
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Apr 19 2020 17:01:43 GMT-0400 (Eastern Daylight Time)
          M550 P"Daniel Ender 5 Duet 2 Wifi" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S0 ; physical drive 0 goes backwards
          M92 X80.00 Y80.00 Z811.00 E409.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E4000.00 ; set maximum instantaneous speed changes (mm/min)
          M201 X6000.00 Y6000.00 Z60.00 E4000.00 ; set accelerations (mm/s^2)
          M203 X15000.00 Y15000.00 Z600.00 E8000.00 ; set maximum speeds (mm/min)
          M204 P800 T2000 ; set accel for XY print (P) and travel moves (T).
          M207 S0.85 R-0.000 F3200 T2600 Z0.0 ; set firmware retraction
          M572 D0 S0.050 ; set pressure advance
          M906 X850 Y850 Z850 E850 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; set idle timeout
          M208 X220 Y220 Z300 S0 ; set axis maxima
          M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
          M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
          M574 Z1 S2 ; configure Z-probe endstop for low end on Z
          M558 P9 C"zprobe.in" H5 F120 T12000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X-45 Y3 Z1.95 ; set Z probe trigger value, offset and trigger height
          M557 X15:160 Y15:200 S20 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 A88.4 C265.5 D2.0 S1.00 V23.9 B0 ; disable bang-bang mode for the bed heater and set PWM limit (Values copied from auto tune D corrected from 0.9 to 2 by Phaedrux)
          M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
          M143 H1 S300 ; set temperature limit for heater 1 to 300C
          M307 H1 A390.6 C153.8 D3.5 S1.00 V23.9 B0 ; disable bang-bang mode for heater and set PWM limit (Values copied from auto tune)
          M563 P0 S"E3D V6 Nozzle X" D0 H1 F0 ; define tool 0
          Enjoy printing!!!
