    Cant reach 5mm/s volumetric feed rate with the Titan Aero. Help.
    • Turboundefined
      Turbo
      Ive reinstalled a titan aero on my printer, and now i cant get it to extrude properly. Weird thing is it used to work perfectly. I was able to reach a 5mm/s volumetric flow before, but now i have trouble reaching 3mm/s. Ive reassembled, adjusted tension, nothing. using a .5mm nozzle and 1.75mm PLA+
      • Some things ive noticed:
      • 210c and 235c dont make a difference with extruding
      • im using the same thermistor and heater cartridge that was on my chimera, so the thermistor reading should be proper... right?
      • No heat creep, got a good fan on the heatsink
      • the filament immediately becomes much larger in diameter after leaving the hotend. its similar behavior to when i used some silk filaments, but it cant seem to keep up with extrusion
      What could i be missing. I know it can reach 5mm/s feedrate, because i did it a few months ago with no issues right out of the box
      Cant stop tuning wont stop tuning.
      Dbot, Custom i3, Voron 0&2
      PaulHewundefined 1 Reply Last reply Reply Quote 0
      • PaulHewundefined
        PaulHew @Turbo
        @Turbo said in Cant reach 5mm/s volumetric feed rate with the Titan Aero. Help.:
        Watching this post with interest, as I have noticed that with my titan Aero and my E3D V6 on my RailCore when I was calculating max vol rate.
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        Turboundefined 1 Reply Last reply Reply Quote 0
        • Turboundefined
          Turbo @PaulHew
          @PaulHew SOOOOO about that... i remembered im using a different extruder motor, and i didnt realize that the old one is 0.9 degrees, so i was going for 10mm/s vol flow in reality because the new one is 1.8
          SO CHECK STEPS/MM PEOPLE
          im an idiot
