    Get Output Pin States for Conditional GCode
    Gcode meta commands
    420
    • webdes03
      webdes03 last edited by
      I have relays connected to "out8" and "out9" on my Duet 3, for the purpose of powering a mister and vacuum.
      ;Set up vacuum and misting outputs
      M950 P2 C"out8" ; define P2 as vacuum
      M950 P3 C"out9" ; define P3 as mister
      Everything works correctly, and I added M7/9/10/11.gfiles to enable those functions):
      # M7.g
      M42 P3 S1	; enable mister
      G4 P2000	; wait for 2 seconds
      # M9.g
      M42 P3 S0	; disable mister
      Now, I'm trying to create macros to toggle the mister and vacuum on and off, but I can't figure out how to read the outputs to determine if they're on or not so I can do the appropriate action of the toggle (turn it on of it's off, or off if it's on).
      Presumably I can do something like the following, I just can't seem to master the right solution to make it work:
      # ToggleMister.g
      if P3 EQ 0
        M7
      else
        M9
      • SpoonUnit
        SpoonUnit last edited by SpoonUnit
        The current value of the pin will be in the object model under sensors probably. Explore the object model using the console in DWC using
        M409 F"v" K"sensors"
        I think you'll find your pin values under
        M409 F"v" K"sensors.inputs"
        e.g.
        M409 F"v" K"sensors.inputs[1].value"
        Once you've nailed it. You can then use echo to test the value and trigger the tool to test changes
        echo sensors.inputs[1].value
        Now you're in position to use the conditional GCODE. Following what you have above, this might look like this
        if sensors.inputs[1].value
            M7
        else
            M9
        • webdes03
          Hmmm... let me poke around. I only see inputs, not outputs... but maybe it's staring me in the face and it's just not "clicking".
          • webdes03
            And by "I only see inputs", I mean endstops...
                "key": "sensors",
                "flags": "v",
                "result": {
                    "analog": [],
                    "endstops": [
                            "triggered": false,
                            "type": "inputPin"
                            "triggered": false,
                            "type": "inputPin"
                            "triggered": false,
                            "type": "inputPin"
                            "triggered": false,
                            "type": "inputPin"
                    "filamentMonitors": [],
                    "inputs": [],
                    "probes": [
                            "calibrationTemperature": 25.0,
                            "deployedByUser": false,
                            "disablesHeaters": false,
                            "diveHeight": 5.0,
                            "maxProbeCount": 1,
                            "offsets": [
                                0,
                                0
                            "recoveryTime": 0,
                            "speed": 2.0,
                            "temperatureCoefficient": 0,
                            "threshold": 500,
                            "tolerance": 0.030,
                            "travelSpeed": 100.0,
                            "triggerHeight": 0.700,
                            "type": 0,
                            "value": [
                                1000
            • webdes03
              Just in case the full dump helps diagnose anything:
              I am running RC7 if that makes a difference.
              M409.json
              • T3P3Tony
                Just confirmed with @dc42 that output pin States are not yet in the Object Model however there are plans to add them.
                www.duet3d.com
                  I've just added output pin states to the OM, so it will be in the next release.
                  • webdes03
                    Ahh awesome, thanks guys!
