    Help with Firmware version. I have a Duet Ethernet 1.0 board.
    Firmware installation
    130
    • Lorncampbell
      Lorncampbell last edited by
      Help with Firmware version. I have a Duet Ethernet 1.0 board. What firmware version do I upgrade to? And a link to it? I can only see Duet-2 or Duet 06/085 information? Help appreciated!
      Current setup is:
      Firmware Name: RepRapFirmware for Duet Ethernet
      Firmware Electronics: Duet Ethernet 1.0
      Firmware Version: 1.19 (2017-08-14)
      Web Interface Version: 1.19
      Web Interface by Christian Hammacher
      Licensed under the terms of the GPL v3
        All Duet WiFis and Duet Ethernets are Duet 2 boards even though the hardware board revision is 1.0, 1.01 etc.
          Since you're running 1.19, see these instructions: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_If_your_Duet_2_WiFi_is_running_main_firmware_1_19_or_later
            dc42 administrators @Phaedrux last edited by dc42
            ... and also https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Upgrading_a_Duet_2_WiFi_or_Ethernet_from_firmware_1_20_or_earlier_to_1_21_or_later.
            I suggest you upgrade to firmware 2.05.1 for now.
            Lorncampbell 1 Reply Last reply Reply Quote 0
            • Lorncampbell
              Lorncampbell @dc42 last edited by
              Hello, thanks for answering
              So, just to clarify
              Release 2.05.1
              download Duet2CombinedFirmware.bin
              rename this to:
              DuetEthernetFirmware.bin
              upload this to the board.
              Question - do I need to also update with DuetWebControl-1.22.6 or is that all included in the main combined firmware?
              thanks Lorncampbell
                Yes you will need to update the DWC files as well. And also likely the wifi server firmware.
                Lorncampbell droftarts 2 Replies Last reply Reply Quote 0
                • Lorncampbell
                  Lorncampbell @Phaedrux last edited by
                  @Phaedrux
                  Great thanks!
                  • droftarts
                    droftarts administrators @Phaedrux last edited by
                    @Phaedrux said in Help with Firmware version. I have a Duet Ethernet 1.0 board.:
                    Nope, he's got a Duet 2 Ethernet! Also, all the caveats and provisos that relate to the Duet 2 WiFi don't apply.
                    Also, DWC 1.22.6 is the last of the v1 DWC versions, and will continue to run fine. You can actually upload the latest DWC (2.1.3) to the SD card, and leave DWC 1.22.6 on it, and swap back and forth between them. If you type your Duet's IP address into your web browser, you'll get 2.1.3, if you add /reprap.htm on the end of the IP address, you'll get DWC 1.22.6.
                    Phaedrux Lorncampbell 2 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @droftarts last edited by
                      @droftarts 🤦 👓 where's my glasses.
                      • Lorncampbell
                        Lorncampbell @droftarts last edited by
                        @droftarts
                        Thanks to all for your help. All uploaded with no problems.
                        So I can load DWC 2.1.3 as well? Install in the same way via Settings/General upload?
                        May try that later
                        thanks again
                        Lorn
                          Yes you can. Just upload the entire zip file to the system folder and it should detect and install it.
                          There seemed to be a few bugs in 2.1.3, so maybe at this time stick with 2.0.7.
                            Actually, it appears that 2.1.4 is out. Please try that one.
