    paneldue cable connection
    165
    • Leblond
      Leblond last edited by
      buona sera ragazzi
      ho acquistato tempo fa il paneldue 7i v3 ma non mi hanno mandato il cavo quindi me lo faccio io, ma avrei bisogno di sapere lo schema di collegamento, il connettore duet2 wifi indica: da sx a dx ( utxd0 - urxd0 - gnd - 5v ). Ddalla parte del paneldue indica: da sx a dx ( 5v - gnd - dout - din ) a parte i "5v e gnd" gli altri due pin come vanno collegati?
        https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_Duet_2_WiFi_Ethernet_and_Maestro
        https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/6bEPHwKRdcF42Drv.large
        Leblond 1 Reply Last reply Reply Quote 0
        • Leblond
          Leblond @Phaedrux last edited by
          @Phaedrux grazieee🤗 mi manca solo quello e posso cominciare a stampare
          • Leblond
            intrecciare i fili causa malfunzionamenti a quanto sappiate voi?
              I have braided mine and I haven't seen any issues. It's probably a good idea if you're going to run it along with other wires. The one thing you should look out for is total length. Mine is about 1,2 meters and it's ok. Shorter the better.
              • Leblond
                @Phaedrux ok grazie
                • Leblond
                  misurato 1,30 mt
                    Should be ok.
                      The length of the 4-way cable is not critical, however the resistance per conductor should not exceed 0.1 ohm. The SD card socket on the TFT panel will not be functional. The cables supplied by Escher3D and Duet3D are about 800mm long. There have been reports of cables up to 1500mm long being successfully used. Take care to route the cable away from motor and endstop cables. Twisting the cables may help prevent cross talk interference.
                      • Leblond
                        @Phaedrux per la presa sd non e' un problema, uso quella interna al paneldue al massimo uso quella del duet2, provo se vedo che crea problemi vedro' di accorciare il cavo
                          To use the PanelDue SD slot you must use the 10-pin ribbon cable which is much shorter and harder to route.
                          • Leblond
                            ho il paneldue 7i V3, e' tutto integrato
                            • Leblond
                              ti mando foto
                              • Leblond
