    How do I configure my default fan?
    967
    • maroondsundefined
      maroonds @droftarts
      @droftarts This was my setup on RRF3 (now I'm on 2.05.1):
      M950 F3 C"e1heat"
      M106 P3 H1 T35 S1
      M950 F2 C"nil"
      M950 F0 C"fan2" Q500
      M106 P0 I0 C"5015" S0 H-1
        droftarts administrators @maroonds
        @maroonds try S255 . Any reason you rolled back from RRF3? Where the fans not working? Setting the part cooling fan with P0 and not thermostatic or bound to a tool should put it under slicer or manual control.
        As this is a Maestro, I’m not sure if pin A2 is correct for Heater 1. It should be. @dc42 ?
        maroondsundefined 1 Reply Last reply Reply Quote 1
        • maroondsundefined
          maroonds @droftarts
          @droftarts I don't know what I did wrong yesterday, but now it's working.
          At least this command: M106 P2 A2 H-1 s255
          But how can I make it thermostatic controllable?
          This is my current setup:
          M106 P0 A22 H-1 S1 ; Part cooling fan
          M106 P3 A2 H1 T45 ; Hotend fan
          M307 H2 A-1 C-1 D-1 ; Disables H2
            dc42 administrators @maroonds
            @maroonds said in How do I configure my default fan?:
            The M307 command must come before the M106 P3 A2 command.
            • maroondsundefined
              maroonds @dc42
              Now everything is working! Thanks @droftarts @dc42
