Setting Z offset in Gcode
Hi all,
I recently acquired a magnetic steel removable bed surface. Smooth on one side and textured on the other . The textured side needs a different Z offset than the smooth and id prefer not to have to edit config.g everytime.
In my start script gcode from my slicer can i simply add the line
G31 P500 X30 Y-10 Z 0.90 ?
Would G31 Z0.90 work ??
( smooth side needs Z 0.75)Just thought id check before I gouge a shape into my new bed !!
Thanks in advance
Phil -
@Phil-Maddox said in Setting Z offset in Gcode:
Yes. You can send the main Gcode with any of the individual parameters by themselves to update just that parameter. The others that were already set previously will remain in place.
@Phil-Maddox, you can also set the Z offset in your slicer's UI. This is what I do.
