    Stupid question.
    • Stevo
      Stevo last edited by
      Is it possible to hook up to the duet2 via wifi using simplify 3d software so I can use the live preview tracking feature of the software?
      gtj0 1 Reply Last reply Reply Quote 0
      • gtj0
        gtj0 @Stevo last edited by
        @Stevo said in Stupid question.:
        I've only been able to get it to work via USB.
        Stevo 1 Reply Last reply Reply Quote 0
        • Stevo
          Stevo @gtj0 last edited by
          @gtj0 said in Stupid question.:
          Thanks for the reply I had to ask more out of curiosity
          • A Former User
            A Former User last edited by
            not familiar with how s3d works, but enabling telnet on the duet and installing a virutal com port that is linked to the duet on the telnet port might work similarly as if it was connected via usb
            • gtj0
              gtj0 @Guest last edited by
              @bearer S3D is very picky about its ports. On Linux, it won't accept a "virtual" serial device like you'd create with socat. I can't try Windows but it might be worth a shot.
              A Former User 1 Reply Last reply Reply Quote 0
              • A Former User
                A Former User @gtj0 last edited by A Former User
                just occured to me using any esp8266-ish (board be it nodemcu/wemos d1 mini etc) you could probably combine Duet telnet with esplink firmware on the esp8266 to get you a hardware serial port that is networked to the Duet.
                (but printing from the duets SD card is one of the bigger features)
                ((and with RC11 you could also get raw g-code from the PanelDue port to put into another esplink to avoid telnet))
