    Excluding points from mesh bed level
    Firmware wishlist
    • Dezdoghound
      Dezdoghound last edited by
      Due to the shape of my printer/toolhead, there are specific points on the bed that the probe cannot reach. However, later on down the axis it is able to reach them, so am I able to exclude points from a mesh level?
      e.g. I want to mesh level from X0:200, Y0:200 s20 but exclude (0,0) and (200,0)?!
      zapta 1 Reply Last reply Reply Quote 1
        Not that I'm aware of. Moved to firmware wishlist forum.
        • zapta
          zapta @Dezdoghound last edited by
          @Dezdoghound, your bed is not convex and when duet goes in a straight line from point A to point B it may hit an obstacle. This may be a bigger problem.
          One simple workaround to to limit the duet to a rectangular area.
          Dezdoghound 1 Reply Last reply Reply Quote 0
          • Dezdoghound
            Dezdoghound @zapta last edited by
            @zapta
            What I've done for now is just mark out on the slicer where the unusable areas are. The mesh probe currently only does a rectangle where it isn't constrained by those points.
            • Baenwort
              Baenwort last edited by
              I thought I remembered this was possible long ago and I checked the Wiki.
              https://duet3d.dozuki.com/Wiki/Gcode#Section_M557_Set_Z_probe_point_or_define_probing_grid
              You used to be able to define the probe points on a Cartesian bed like you can with a Delta back in the 1 series firmware.
              It sounds like Phaedrux thinks it might happen again some day.
              • antlestxp
                antlestxp last edited by
                this would be nice to see working again so I can avoid the location of the magnets I have under my PCB bed.
