    Duet wifi 2 reset when trying to home printer w smart effector
    548
    • chrisundefined
      chris
      I have a 12v delta running 0.9 degree stepper motors each with 2 amps and a 25 amp psu and when i home printer get watchdog timeout error i am using duet smart effector. @dc42 any thoughts cheers.
      === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05RC2 running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-9T6BU-FG3SN-6J1DD-3S86J-TBZRF<LF>Used output buffers: 1 of 24 (1 max)<LF>=== RTOS ===<LF>Static ram: 25688<LF>Dynamic ram: 92652 of which 348 recycled<LF>Exception stack ram used: 296<LF>Never used ram: 12088<LF>Tasks: NETWORK(ready,1280) HEAT(blocked,872) MAIN(running,3800) IDLE(ready,200)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:55 ago, cause: software<LF>Last software reset time unknown, reason: Watchdog timeout, spinning module Platform, available RAM 11396 bytes (slot 1)<LF>Software reset code 0x0050 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x14433014 BFAR 0xe000ed38 SP 0x2001fe64 Task 0x5754454e<LF>Stack: 0040d3db 0040d4dc 6100001f 20012c10 00000000 2000c960 0002f59e 2000c870 fffffff1 2000c960 00000000 0002f59e 20012bb0 00000007 0041922d 00419322 21000027 2000ba7c 2000c870 20007fc0 20007fc0 40090000 03e38406<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed:[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
        Upgrade to 2.05.1 and change your YAT end of line settings so that we can see the full M122
        • chrisundefined
          chris
          end of line setting not used yat before so not sure how to
            It's in the text terminal settings of YAT
            Setup YAT to use <LF> as the end of line character. Go to "Terminal" Menu -> "Settings" -> "Text Settings" -> "EOL sequence:" set to <LF>
            • chrisundefined
              chris
              @Phaedrux said in Duet wifi 2 reset when trying to home printer:
              2.05.1
              is it combined firmware "https://github.com/dc42/RepRapFirmware/releases/download/2.05.1/Duet2CombinedFirmware.bin2" ?
              • chrisundefined
                chris
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                Used output buffers: 1 of 24 (13 max)
                Static ram: 25712
                Dynamic ram: 92696 of which 304 recycled
                Exception stack ram used: 328
                Never used ram: 12032
                Tasks: NETWORK(ready,676) HEAT(blocked,848) MAIN(running,3816) IDLE(ready,160)
                Owned mutexes:
                Last reset 00:04:19 ago, cause: software
                Last software reset at 2020-04-30 22:17, reason: Watchdog timeout, spinning module Platform, available RAM 11556 bytes (slot 2)
                Software reset code 0x4050 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f014 BFAR 0xe000ed38 SP 0x2001ff04 Task 0x4e49414d
                Stack: 0041922d 004192f6 21000027 2000ba7c 2000c870 20007fc0 20007fc0 40090000 0964e770 20000660 00419979 09622875 2000ba78 2000ba7c 0041ba45 0964e770 00419001 20007fc0 00000004 20017698 2000065c 00000006 00000007
                Error status: 10
                SD card longest block write time: 366.0ms, max retries 0
                MCU temperature: min 31.0, current 31.4, max 31.8
                Supply voltage: min 12.6, current 12.9, max 13.0, under voltage events: 0, over voltage events: 0, power good: yes
                Date/time: 2020-04-30 22:36:21
                Cache data hit count 774859868
                Slowest loop: 51.68ms; fastest: 0.07ms
                Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                === DDARing ===
                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                Heater 1 is on, I-accum = 0.0
                Segments left: 0
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is ready with "M122" in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 367.54ms; fastest: 0.00ms
                HTTP sessions: 0 of 8
                • WiFi -
                  Network state is running
                  WiFi module is providing access point
                  WiFi firmware version 1.23
                  WiFi MAC address 86:f3:eb:83:4d:bc
                  WiFi Vcc 3.44, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 24776
                  WiFi IP address 192.168.102.60
                  Connected clients 0
                  What LEDs are lit on the smart effector?
                  What gcode are you running when this happens?
                  chrisundefined 1 Reply Last reply Reply Quote 0
                  • chrisundefined
                    chris
                    no lights on smart effector only green when tapped , not fully wires smart effector up just testing printer homing before, tried unplugging but still get same issue.
                    • Danalundefined
                      Danal
                      When you first power up, does the green led on the smart effector flash, and if so, how many times?
                      • chrisundefined
                        chris
                        @Danal , just flashes green twice then stops.
                        • chrisundefined
                          chris
                          do u think worth just resetting duet 2 board
                            Does it home the printer and then reset; or reset without moving the carriages at all?
                            Please post your homedelta.g file.
                            • chrisundefined
                              chris @Phaedrux
                              @Phaedrux G28
                              • chrisundefined
                                chris @dc42
                                @dc42 nope tries to move carriages home then trips
                                dc42undefined chrisundefined 2 Replies Last reply Reply Quote 0
                                  dc42 administrators @chris
                                  @chris said in Duet wifi 2 reset when trying to home printer w smart effector:
                                  Are sure you have the endstop switches connected to the right pins on the connectors on the Duet?
                                  • chrisundefined
                                    chris @chris
                                    @dc42, here is homedelta.g
                                    ; homedelta.g
                                    ; generated by RepRapFirmware Configuration Tool on Sat Oct 27 2018 13:30:24 GMT+0100 (British Summer Time)
                                    G91 ; relative positioning
                                    ;*** Slow homing has been configured. Change F480 to F4800 below when your configuration is working
                                    G1 S1 X625 Y625 Z625 F4800 ; move all towers to the high end stopping at the endstops (first pass)
                                    G1 X-5 Y-5 Z-5 F4800 S2 ; go down a few mm
                                    G1 S1 X10 Y10 Z10 F480 ; move all towers up once more (second pass)
                                    G1 Z-5 F4800 ; move down a few mm so that the nozzle can be centred
                                    G90 ; absolute positioning
                                    G1 X0 Y0 F4800 ; move X+Y to the centre
                                    • chrisundefined
                                      chris @dc42
                                      @dc42 yes, x stop, y stop and z stop. on duet web says endstop 0 , 1 , 2 not triggered and endstop 3 is triggered.
                                      • chrisundefined
                                        chris
                                        Even disconnecting everything a part from endstops and trying each moter cause board to reset
                                        • chrisundefined
                                          chris
                                          re uploading replicator configuration seemed to have solved it but not sure why in first place
