    Why is the print inverted?
    • luckyflyerundefined
      luckyflyer
      I finally got my Duet 3 brained core xy printer going and did a benchy. It came out ok for a first print with no tuning but for some reason the print is inverted. My guess is something is reversed but what?
      • bbergerundefined
        bberger
        The motors. Switch the X and Y assignment and you should be good.
        Could be that you'll need to invert the direction also.
          luckyflyer
          So just plug x into y and y into x?
            Follow the directions here for testing motor directions on Corexy before you swap anything.
            https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Movement_section
            The results will tell you exactly what to change.
            Also be aware that it assumes a right hand coordinate system. X+ to the right, Y+ to the rear.
              luckyflyer
              Ok, thanks again.
