    How to cancel a macro
      jay_s_uk
      I want to run a long macro to test my toolchanger before I start printing with it.
      I was planning to just have a ton of T0's and T1's.
      Is there a way to cancel a macro if I run into an issue without using the emergency stop button?
      mwwhitedundefined 1 Reply Last reply Reply Quote 0
        You could have the macro test an endstop switch during the loop.
        • mwwhitedundefined
          mwwhited @jay_s_uk
          This post is deleted!
            jay_s_uk
            So something along the lines of carrying out the macro using interactions?
            And then inserting a check for an endstop being pressed and add an extra physical button to stop the macro?
            Can I add an extra endstop without adding an extra axis?
            • botundefined
              bot
              You could have the macro start a print, the print file being the test gcode you wish to run.
              *not actually a robot
