    Windows unable to flash Duet3 despite BOSSA port showing...
    753
    • Jim46undefined
      Jim46
      Upon updating the RFF to get fresh files for the DWC and restarting it i get the following warnings:
      Not sure how to address the M550 message...
      • Jim46undefined
        Jim46
        Hi Phaedrux, Here are the M122 results...
        5/6/2020, 12:19:16 PM 	M122
        RepRapFirmware for Duet 3 v0.6 version 3.0beta11 running on Duet 3 version v0.6
        Board ID: 08DJM-956L2-G43S4-6J9F8-3SJ6R-9B6AG
        Used output buffers: 1 of 32 (7 max)
        Static ram: 68792
        Dynamic ram: 171592 of which 52 recycled
        Exception stack ram used: 300
        Never used ram: 152480
        Tasks: NETWORK(ready,1980) HEAT(blocked,1420) CanReceiv(suspended,3808) CanSender(suspended,1476) CanClock(blocked,1432) TMC(blocked,216) MAIN(running,4416) IDLE(ready,156)
        Owned mutexes:
        Last reset 00:05:11 ago, cause: software
        Last software reset at 2020-05-06 19:14, reason: Unknown, spinning module Platform, available RAM 152480 bytes (slot 2)
        Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04429000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
        Error status: 0
        Free file entries: 10
        MCU temperature: min 34.5, current 35.1, max 35.3
        Supply voltage: min 23.7, current 23.8, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
        Driver 0: standstill, reads 7347, writes 14 timeouts 0, SG min/max 0/0
        Driver 1: standstill, reads 7347, writes 15 timeouts 0, SG min/max 0/0
        Driver 2: standstill, reads 7352, writes 11 timeouts 0, SG min/max 0/0
        Driver 3: standstill, reads 7353, writes 11 timeouts 0, SG min/max 0/0
        Driver 4: standstill, reads 7349, writes 15 timeouts 0, SG min/max 0/0
        Driver 5: standstill, reads 7355, writes 11 timeouts 0, SG min/max 0/0
        Date/time: 2020-05-06 19:19:15
        Slowest loop: 7.04ms; fastest: 0.25ms
        Hiccups: 0, FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
        === MainDDARing ===
        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is idle in state(s) 0
        aux is idle in state(s) 0
        daemon* is ready with "M122" in state(s) 0
        queue is idle in state(s) 0
        lcd is idle in state(s) 0
        spi is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 0.80ms; fastest: 0.01ms
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
        HTTP sessions: 0 of 8
        - Ethernet -
        State: 2
        === CAN ===
        Messages sent 0, longest wait 0ms for type 0
        === Linux interface ===
        State: 0, failed transfers: 0
        Last transfer: 33ms ago
        RX/TX seq numbers: 47510/9933
        SPI underruns 0, overruns 0
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v1.1.0.5
        Code buffer space: 4096
        Configured SPI speed: 2000000 Hz
        Full transfers per second: 0.30```
        code_text
        • A Former User?
          A Former User @Jim46
          @Jim46 said in Windows unable to flash Duet3 despite BOSSA port showing...:
          set the name after M550 to "duet3" or put a ; in front of M550 to eliminate it all together (its only really used when in stand alone mode)
          • Jim46undefined
            Jim46
            Wow! After the updates to RRF and DWC. I ran Z+25; Y+50 and X+50. Y and Z worked! Two motors on Y and two motors on Z and the both turned!
            X+50 did nothing but gave me errors on being disconnected. It referenced drive 0. That one is empty. X motor is on 1 i hope.
            Here is the physical set up...
            The Wiring diagram ...
              Hi Jim, sounds like you've gotten some positive progress now.
              • A Former User?
                good progress, I think that is solved by changing the drive mapping to M584 E0 X1 Y2:3 Z4:5 ; set drive mapping dual y on 2&3 + dual z on 4&5
                • Jim46undefined
                  Jim46
                  @bearer said in Windows unable to flash Duet3 despite BOSSA port showing...:
                  Updated Config.g with this M584 code. Wonderful improvement.
                  Single X motor moves on + and - commands
                  Two Y motors move on + and - commands
                  Tried to run Z motors... gave + and - commands... the Y motors moved slowly in + and - directions.
                  No Z motor movement.
                  Here's is the config.g
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 04 2020 10:26:28 GMT-0600 (Mountain Daylight Time)
                  G90                            ; send absolute coordinates...
                  M83                            ; ...but relative extruder moves
                  M550 P"duet3"             ; set printer name
                  M552 P0.0.0.0 S1               ; enable network and acquire dynamic address via DHCP
                  M586 P0 S1                     ; enable HTTP
                  M586 P1 S0                     ; disable FTP
                  M586 P2 S0                     ; disable Telnet
                  M569 P0 S1                   ; physical drive 0 goes forwards
                  M569 P1 S1                   ; physical drive 1 goes forwards
                  M569 P2 S1                   ; physical drive 2 goes forwards
                  M569 P3 S1                   ; physical drive 3 goes forwards
                  M569 P4 S1                   ; physical drive 4 goes forwards
                  M569 P5 S1                   ; physical drive 5 goes forwards
                  M350 X16 Y16 Z16 I1            ; configure microstepping with interpolation
                  M92 X53.33 Y53.33 Z53.33       ; set steps per mm
                  M566 X900.00 Y900.00 Z12.00    ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z180.00 ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z20.00    ; set accelerations (mm/s^2)
                  M906 X800 Y800 Z800 I30        ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                        ; Set idle timeout
                  M208 X0 Y0 Z0 S1               ; set axis minima
                  M208 X1000 Y1000 Z1000 S0      ; set axis maxima
                  M574 X1 S1 P"io1.in"
                  M574 Y1 S1 P"io2.in"
                  M574 Z1 S1 P"io3.in"
                  M558 P0 H5 F120 T6000          ; disable Z probe but set dive height, probe speed and travel speed
                  M557 X0:1000 Y0:1000 S50       ; define mesh grid
                  M302 P1 ; allow cold extusion
                  any ideas
                    Phaedrux Moderator @Jim46
                    Hi Jim, I think you'll need to set some values for the E axis in these commands.
                    M350 X16 Y16 Z16 E16 I1            ; configure microstepping with interpolation
                    M92 X53.33 Y53.33 Z53.33 E400     ; set steps per mm
                    M566 X900.00 Y900.00 Z12.00 E2000   ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 Y6000.00 Z180.00 E6000; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z20.00 E3000   ; set accelerations (mm/s^2)
                    M906 X800 Y800 Z800 E800 I30        ; set motor currents (mA) and motor idle factor in per cent
                    Note I just guessed at the values for steps per mm, etc etc for your extruder. You'd need to have an educated guess on what they should be.
                    • A Former User?
                      A Former User
                      I think its over to the config wizzards now, they're all over the forum:)
                      • Jim46undefined
                        Jim46
                        Hi Phaedrux,
                        Just edited config.g with your suggestions adding E400 to M92; E2000 to M566; E6000 to M203; and E3000 to M201.
                        No change to motor behavior. No Z motor movement. Y motors do both Y and Z commands. Some sort of motor confusion.
                        • A Former User?
                          A Former User
                          Maybe roll back the dual motor drive and test each driver individually. Simplest would be to first test
                          M584 E0 X1 Y2 Z4 and then M584 E0 X1 Y3 Z5 and see what moves.
                          if you put all three lines in your config.g file you can easily select which is inactive by placing a ; in from of them.
                          so test Y on driver 2 + Z on driver 4
                          ;M584 E0 X1 Y2:3 Z4:5 ; set drive mapping dual y on 2&3 + dual z on 4&5
                          M584 E0 X1 Y2 Z4
                          ;M584 E0 X1 Y3 Z5
                          then test Y on driver 3 + Z on driver 5
                          ;M584 E0 X1 Y2 Z4
                          M584 E0 X1 Y3 Z5
                          and when you're ready to go back do the original
                          ;M584 E0 X1 Y2 Z4
                          ;M584 E0 X1 Y3 Z5
                          • Jim46undefined
                            Jim46
                            Hi Bearer, here is the setup now
                            M584 E0 X1 Y2 Z4             ; set drive mapping dual y on 2&3 + dual z on 4&5
                            M584 E0 X1 Y3 Z5             ; new set up 050820 date
                            M203 X6000.00 Y6000.00 Z180.00 E6000 ; set maximum speeds (mm/min)
                            First test: This set up caused the X motor to run as expected.
                            Also a single Y motor moved (Not both)
                            And, wonderful, now a Z motor moved (not both).
                            I would have expected both Y motors and Z motors to move together/
                            Is there something I've not set right?
                            thanks,
                            Jim
                            • A Former User?
                              A Former User
                              Only one M584 line at the time and test the drivers do work independently.
                              The ideal outcome is y on driver 2 moves and z on driver 4 moves, then put in the second line and hopefully y on driver 3 and z on driver 5 will move.
                              then after verifying each move independently get back to trying to get both to move.
                              • Jim46undefined
                                Jim46
                                more precisely;
                                X motor on Driver 1 moved +/-
                                Y motor on Driver 3 moved +/-
                                Z motor on Driver 5 moved +/-
                                Driver 2 & 4 no response.
                                • A Former User?
                                  presumably because the second M584 line overrode the first; remove or comment out the second line and verify drivers 2 and 4 work.
                                  • Jim46undefined
                                    Jim46
                                    ;M584 E0 X1 Y3 Z5             ; new set up 050820 date
                                    this caused:
                                    Succcesful movements,
                                    Y motor on Driver 2 moves +/-
                                    Z motor on Driver 4 moves +/-
                                    • Jim46undefined
                                      Jim46
                                      At this point I've been able to verify successful movements of motors on:
                                      X moves +/- on Driver 1
                                      Y1 on Driver 2 moves +/-
                                      Y2 on Driver 3 moves +/-
                                      Y1 and Y2 not together
                                      Z1 on Driver 4 moves +/-
                                      Z2 on Driver 5 moves +/-
                                      Z1 and Z2 not together
                                      • Jim46undefined
                                        Jim46
                                        Can you write this and would it work?
                                        M584 E0 X1 Y2 Y3 Z4 Z5
                                        • A Former User?
                                          ah, they all worked independently then, thats good.
                                          afaik the correct syntax was M584 E0 X1 Y2:3 Z4:5 but it could be some of the other commands require changes. Suggest you end this thread and create a new called "Independent dual X and dual Z" and post your config there to attract a config wizzard
                                          ref https://forum.duet3d.com/topic/7773/forum-feature-mark-as-question-solved/2 on how to tag a thread as solved. first tag as question, then tag as answered.
