    Motors not moving on delta printer with duet wifi
    329
    • dwmeeundefined
      dwmee
      Hi
      Ive just assembled a delta printer and am in the latter stages of setup. Everything is connected and ive used the configuration tool to set the perameter's. However, try as i might, i cannot get the motors to move. i've been through the forum and tried all suggestions but to no avail. M122 spits out this:
      Used output buffers: 3 of 32 (8 max)
      RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
      Board ID: 08DDM-9FAM2-LW4S4-6J9D6-3SD6K-12S3X
      Static ram used: 21176
      Dynamic ram used: 96080
      Recycled dynamic ram: 1528
      Stack ram used: 1304 current, 4888 maximum
      Never used ram: 7400
      Last reset 00:01:44 ago, cause: power up
      Last software reset reason: User, spinning module GCodes, available RAM 7400 bytes (slot 4)
      Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      MCU temperature: min 40.5, current 42.9, max 43.3
      Supply voltage: min 24.5, current 24.6, max 24.9, under voltage events: 0, over voltage events: 0
      Driver 0: standstill
      Driver 1: standstill
      Driver 2: standstill
      Driver 3: standstill
      Driver 4: standstill
      Date/time: 2020-05-04 20:14:40
      Slowest main loop (seconds): 0.005512; fastest: 0.000034
      MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Bed heater = 0, chamber heater = -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      Network state is running
      WiFi firmware version 1.19.2
      WiFi MAC address 60:01:94:73:56:37
      WiFi Vcc 3.11, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 39552
      WiFi IP address 192.168.1.128
      WiFi signal strength -51dBm
      Reconnections 0
      HTTP sessions: 1 of 8
      Socket states: 2 0 0 0 0 0 0 0
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      i cant see where i,m going wrong, any help would be appreciated
        Please post your config.g.
        What firmware version are you using?
        How are you trying to move the motors?
        • dwmeeundefined
          dwmee
          Hi, thanks for the reply
          Heres the config.g file
          I bought the duet wifi over 18 month ago but only just got it out of the box. The firmware was v1.19. I tried to move the motors prior to updating to the latest last night, resulting with no change in the situation.
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 03 2020 15:31:27 GMT+0100 (British Summer Time)
          M550 P"My Printer" ; set printer name
          M665 R198 L360.22 B198 H500 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
          M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X1200 Y1200 Z1200 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 Z0 S1 ; set minimum Z
          M574 X1 Y1 Z1 S0 ; set active high endstops
          M558 P5 R0.4 H30 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
          G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
          M557 R85 S20 ; define mesh grid
          M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
          M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
          M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            jay_s_uk
            @dwmee
            They won't move without being homed, unless you issue M564 H0.
            • dwmeeundefined
              dwmee
              Thanks for the reply
              Ive just tried your suggestion M564 H0. I get the response - Movement outside the bed is not permitted.
              • dwmeeundefined
                dwmee
                If i try any move, like G1 Y10 for example i get this response:
                M120
                G91
                G1 Y10 F6000
                M121
                Attempt to move the head of a Delta or SCARA printer before homing the towers
                • dwmeeundefined
                  dwmee
                  By the way, despite saying i updated the firmware, it still appears to be on:
                  Firmware Electronics: Duet WiFi 1.0
                  Firmware Version: 1.19.2 (2017-09-01)
                  WiFi Server Version: 1.19.2
                  Web Interface Version: 1.19.3
                    jay_s_uk @dwmee
                    @dwmee
                    you could try to temporarily home the axis
                    G92 x0 y0
                    Before you do so, move the head so the carriages are in the middle of the travel on the towers and the head is in the centre. I would suggest doing that with the power off.
                    You also need to change your endstops from M574 x1 y1 z1 s0 to M574 x2 y2 z2 s0. This is because the endstops are at the top of the towers at the maximum travel.
                    • dwmeeundefined
                      dwmee
                      @jay_s_uk said in Motors not moving on delta printer with duet wifi:
                      G92 x0 y0
                      Thanks for the suggestions
                      However, I still have no movement
                        The correct way to test the motors on a delta printer is described on the delta printer configuration wiki page, https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_and_endstops_individually.
                        • dwmeeundefined
                          dwmee
                          Hi dc42 & jay_s_uk
                          Thank-you for your help and guidance. I have managed to update the firmware to the latest & all seems to work as it should. Continue to be helpful &awsome
                          Regards dwmee
