    Z probe
    • Saroleve
      Saroleve last edited by
      Hi can anyone have a look at my config file for my Tronxy X5sa and duet2 WiFi please, I have most things working and homing except the Z probe isn’t stopping the z axis, it has been wired into permanently on fan connectors and the the signal to the first pin on the z probe connector and the signal wire has a bat 85 soldered into it as described on another post, the sensor lights up if I put something metal under it, also I need it to move over the bed from xy position to detect the bed.
      Thanks
      Configuration file for Duet WiFi (firmware version 2.03)
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue May 05 2020 16:01:20 GMT+0100 (British Summer Time)
      M550 P"Tronxy Xsa" ; set printer name
      M667 S1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
      M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X330 Y330 Z375 S0 ; set axis maxima
      M574 X1 Y1 S0 ; set active low and disabled endstops
      M574 Z1 S2 ; set endstops controlled by probe
      M558 P2 H5 F120 T6000 ; set Z probe type to modulated and the dive height + speeds
      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P500 X100 Y100 Z4 ; set Z probe trigger value, offset and trigger height
      M557 X15:305 Y15:305 S20 ; define mesh grid
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      ; homeall.g
      ; called to home all axes
      G91 ; relative positioning
      G1 H1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-335 ; home X axis
      G1 H1 Y-335 ; home Y axis
      G1 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-335 ; then move slowly to Y axis endstop
      G90 ; absolute positioning
      G1 X-85 Y-85 F6000 ; go to first bed probe point and home Z
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; homex.g
      ; called to home the X axis
      G1 H1 X-335 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F6000 ; go back a few mm
      G1 H2 Z-5 F6000 ; lower Z again
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y-335 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y5 F6000 ; go back a few mm
      G1 H1 Y-335 F360 ; move slowly to Y axis endstop once more (second pass)
      ; homez.g
      ; called to home the Z axis
      G1 X-85 Y-85 F6000 ; go to first probe point
      • droftarts
        droftarts Moderator @Saroleve last edited by
        @Saroleve Are you using the stock TronXY NPN sensor? If so, take a look at the config in this thread: https://forum.duet3d.com/topic/8514/auto-bed-leveling-map-on-tronxy-x5sa
        I'm assuming you have a Duet WiFi, hardware version 1.03 or older, which is why you have added the Bat 85, and then connected to Z-PROBE in, as per https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_NPN_output_normally_open_inductive_or_capacitive_sensor
        From your config.g:
        From the other thread: M558 P5 I1 H5 F120 T6000
        You should set your probe to type P5, which is for switch-type sensors. P2 is expecting to modulate the signal, which an NPN sensor doesn't.
        I1 will invert the probe, which you need to do with NPN sensors.
        The rest is fine. Once the probe is working, you could add A10 R0.5 S0.003 B0 on the end of the M558 command, where A10 sets the number of times to probe a point until it consistently hits the S0.003 tolerance value, R0.5 is a half-second rest between probes (to let it settle) and B0 turns the heaters off during probing (less interference).
        You've set X and Y offsets very high, so the firmware thinks the probe is 100mm away from the hot end in X and Y. This is probably not correct! The other thread has X-30 Y0. For setting Z (once the probe is working) see https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
        Saroleve 1 Reply Last reply Reply Quote 0
        • Saroleve
          Saroleve @droftarts last edited by
          @droftarts thanks Ian for your explanation, I’m completely new to the duet so your help is much appreciated I’ll get on to it and report back👍🏻
