Duet WIFI uploads failing
Every once in awhile i get a rash of failed gcode uploads on my Duet 1.01 board running 1.23. I have attached a PCAP of it happening. Has anyone run into this? This will happen for awhile and clear up hours/days later for a bit. Powering off the printer will not do anything, nor using different browsers. I also turned off CRC checking, extended timeouts and up'd the max ajax connections... all do not seem to help. The file is close to 7mb in the capture, although smaller files from 1mb+ have also failed.
[0_1589068552853_duet-failed-upload.zip](Uploading 100%)
Thanks,
Jim
@jnofsinger said in Duet WIFI uploads failing:
When using Duet Web Control?
Do you mean wifi server 1.23?
What firmware version? what DWC version?
You mention turning off CRC so that must be recent, but what version specifically?
I have the exact same problem and its intermittent. I rolled back to the older DWC and its a little better. weird issue.... good thing i'm not the only one having it.
@bearer Yes when in the web control
