    Many issues after upgrading to 3.0 RC-12
    Firmware installation
    1.7k
    • TheBasedDogeundefined
      TheBasedDoge
      I have just finished running the upgrade to get from 2.05 up to 3.0 RC-12. Currently, I have quite a few issues that I am struggling to get through. I am using the reprap firmware configuration tool, although I have a feeling that it is not yet working correctly for this firmware?
      • The first was the X and Y axis refusing to home. I was able to fix the X axis after changing to the following: M574 X1 S1 P"!xstop" ( X now works)
      • Y axis still will not home. After clicking home, the bed will drop a bit, and the Y axis will move towards the endstop about 5mm and then say "Error G0/G1: Insufficient axis homed"
      • Another issue is one I have always had... not sure how to fix. My X endstop is actually OFF the bed, meaning the home would be actually +15mm from the endstop. Not sure how to correctly set this in firmware?
      Here is my endstop config (note that currently only my X will home correctly):
      M574 X1 S1 P"!xstop"                                    ; configure active-low endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop"                                    ; configure active-low endstop for low end on Y via pin ystop
      M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
      Next issue is the BLTouch. If I hold in the Y endstop to trick it into thinking it has homed correctly, the Z will attempt to home. The BLTouch will deploy correctly and the bed will start to raise, however the BLTouch will never trigger as detected. So the hotend would crash into the bed.
      Any help appreciated. Sitting here confused for a few hours already, especially with the endstops.
      (will post configs below, char limit)
      PaulHewundefined 1 Reply Last reply Reply Quote 0
        TheBasedDoge
        Here is my old 2.x config:
        ; generated by RepRapFirmware Configuration Tool v2.1.4 on Tue Dec 17 2019 00:47:57 GMT-0500 (Eastern Standard Time)
        G90                                               ; send absolute coordinates...
        M83                                               ; ...but relative extruder moves
        M550 P"Hypercube"                                ; set printer name
        M564 H0                                           ;allow movement before homing
        M667 S1                                           ; select CoreXY mode
        M550 Phypercube ; Set machine name
        M552 S1; Enable network
        M552 S1; P0
        M586 P1 S1                              ; enable FTP
        M586 P2 S1                              ; enable Telnet
        ;M551 P"............"
        M569 P0 S1                                        ; physical drive 0 goes forwards
        M569 P1 S1                                        ; physical drive 1 goes forwards
        M569 P2 S1                                        ; physical drive 2 goes forwards
        M569 P3 S1                                        ; physical drive 3 goes forwards
        M569 P4 S1                                        ; physical drive 4 goes forwards
        M584 X0 Y1 Z2 E3:4                                ; set drive mapping
        M350 X16 Y16 Z16 E16:16 I1                        ; configure microstepping with interpolation
        M92 X80.00 Y80.00 Z400.00 E86:86                  ; set steps per mm
        M566 X1600 Y1600 Z12 E120:120                     ; Set maximum instantaneous speed changes (mm/min)
        M203 X8000 Y8000 Z180 E1200:1200                  ; Set maximum speeds (mm/min)
        M201 X4000 Y4000 Z250 E2000:2000                  ; Set accelerations (mm/s^2)
        M906 X800 Y800 Z800 E900:900 I30                  ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                           ; Set idle timeout
        M208 X0 Y0 Z0 S1                                  ; set axis minima
        M208 X300 Y300 Z230 S0                            ; set axis maxima
        M574 X0 Y0 S0                                    ; set active low endstops
        M574 Z1 S2                                       ; set endstops controlled by probe
        M307 H7 A-1 C-1 D-1                               ; disable heater on PWM channel for BLTouch
        M558 P9 H5 F500 T4000 X0 Y0 Z1                    ; set Z probe type to bltouch and the dive height + speeds
        M558 P9 H5 F100 T2000
        G31 P25 X20 Y5 Z2                               ; set Z probe trigger value, offset and trigger height
        M557 X20:275 Y5:275 S92                          ; define mesh grid
        M143 S280 ; Set maximum heater temperature to 260C
        M305 P1 T100000 B4725 C0.0000000706 R4700 ; Set thermistor + ADC parameters for heater 1
        M305 P2 T100000 B4725 C0.0000000706 R4700 ; Set thermistor + ADC parameters for heater 2
        M106 P0 S0 I0 F500 H-1 				  ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S1 I0 F500 H-1 				  ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P2 S1 I0 F500 H1:2 T100 			  ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M563 P0 D0 H1                           	  ; Define tool 0
        G10 P0 X0 Y0 Z0 				  ; Set tool 0 axis offsets
        G10 P0 R0 S0 					  ; Set initial tool 0 active and standby temperatures to 0C
        M563 P1 D1 H2 					  ; Define tool 1
        G10 P1 X-18.5 Y.7 Z0 				  ; Set tool 1 axis offsets
        G10 P1 R0 S0 				          ; Set initial tool 1 active and standby temperatures to 0C
        • PaulHewundefined
          PaulHew @TheBasedDoge
          @TheBasedDoge You could try removing the "!" so it looks like this.
          M574 X1 S1 P"xstop"			             ; _RRF3
          M574 Y1 S1 P"ystop"			             ; _RRF3
          HTH
          Paul
          RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
          Voron 2.4 disassembled..... Waiting for the RailCore Mini....
          TheBasedDogeundefined 1 Reply Last reply Reply Quote 0
            TheBasedDoge
            Here is my new 3 config so far
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 10 2020 13:55:08 GMT-0400 (Eastern Daylight Time)
            M552 S1                                                ; enable network
            M586 P0 S1                                             ; enable HTTP
            M586 P1 S0                                             ; disable FTP
            M586 P2 S0                                             ; disable Telnet
            M92 X80.00 Y80.00 Z400.00 E86.00:86.00                 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00:120.00             ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00        ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z20.00 E250.00:250.00             ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E800:800 I30                       ; set motor currents (mA) and motor idle factor in per cent
            M208 X300 Y0 Z0 S0                                     ; set axis maxima
            M950 S0 C"exp.heater7"                                 ; create servo pin 0 for BLTouch
            M558 P9 C"zprobe.in+zprobe.mod" H2 F120 T6000          ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X20 Y5 Z2.5                                   ; set Z probe trigger value, offset and trigger height
            M557 X15:300 Y15:300 S20                               ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4138         ; configure sensor 0 as thermistor on pin bedtemp
            M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
            M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
            M307 H0 B1 S1.00                                       ; enable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                                ; map heated bed to heater 0
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
            M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
            M143 H1 S280                                           ; set temperature limit for heater 1 to 280C
            M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
            M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp
            M950 H2 C"e1heat" T2                                   ; create nozzle heater output on e1heat and map it to sensor 2
            M143 H2 S280                                           ; set temperature limit for heater 2 to 280C
            M307 H2 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
            M950 F0 C"Part Fan" Q500                                   ; create fan 0 on pin fan0 and set its frequency
            M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"Hotend" Q500                                   ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S1 H1:2 T100                                   ; set fan 1 value. Thermostatic control is turned on
            M563 P0 S"Right Nozzle" D0 H1 F0                       ; define tool 0
            G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
            G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
            M563 P1 S"Left Nozzle" D1 H2 F0                        ; define tool 1
            G10 P1 X0 Y0 Z0                                        ; set tool 1 axis offsets
            G10 P1 R0 S0                                           ; set initial tool 1 active and standby temperatures to 0C
            ; Custom settings
            M575 P1 B57600 S1                                      ;paneldue settings
            ;M564 H0                                                ;allow movement before homing
              TheBasedDoge @PaulHew
              @PaulHew If I do this the endstop is inverted, it thinks its triggered until I click it. The actual endstops seem to be working fine. It's just that when I home it it won't actually travel more than 5mm into the homing direction for some reason
              PaulHewundefined 2 Replies Last reply Reply Quote 0
              • PaulHewundefined
                @TheBasedDoge
                Z-Probe
                My CoreXY config for reference
                M558 P9 C"^zprobe.in" H5 R1 F120 T6000 A5 S0.02  ;BLTouch connected to Z probe IN pin
                M950 S0 C"duex.pwm1"				             ;BLTouch Servo (S0) on duet pwm1
                G31 X2 Y42 Z1.605 P25                            ; Customize your offsets appropriately - do a paper test, and put the probed value in the Z value here
                M557 X30:280 Y30:280 S20
                I have edited yours, try this.
                M558 P9 C"^zprobe.in" H5 F120 T6000   A5 S0.02       ; set Z probe type to bltouch and the dive height
                M950 S0 C"exp.heater7"                                 ; create servo pin 0 for BLTouchG31 P500 X20 Y5 Z2.5                                   ; set Z probe trigger value, offset and trigger height
                • PaulHewundefined
                  @TheBasedDoge Are your endstops on the Duex board?
                    TheBasedDoge
                    Everything is plugged into the Duet itself. I have no extra add on boards.
                    The Z-Probe modification you posted I think did the trick, it seemed to probe fine if I do homeall while manually holding down the y endstop. Still having the y issue.
                    • PaulHewundefined
                      @TheBasedDoge try homing the axis individually first. HomeX HomeY HomeZ. Homeall might need some work.
                      Have you posted homeall?
                        TheBasedDoge
                        ; homeall.g
                        ; called to home all axes
                        G91 ; relative positioning
                        G1 H2 Z2 F6000 ; lift Z relative to current position
                        G1 H1 X-305 Y-5 F3600 ; move quickly to X or Y endstop and stop there (first pass)
                        G1 H1 X-305 ; home X axis
                        G1 H1 Y-5 ; home Y axis
                        G1 X5 Y5 F6000 ; go back a few mm
                        G1 H1 X-305 F300 ; move slowly to X axis endstop once more (second pass)
                        G1 H1 Y-5 ; then move slowly to Y axis endstop
                        G90 ; absolute positioning
                        G1 X-5 Y10 F6000 ; go to first bed probe point and home Z
                        ;G91 ; relative positioning
                        ;G1 Z2 F100 ; lift Z relative to current position
                        ;G90 ; absolute positioning
                        Maybe this is the issue. I don't know why Y says -5 but x is -305?
                        • PaulHewundefined
                          PaulHew
                          Just incase your axis is over the other side of the bed, it needs to know how far it can go. It is only a homing move, not bed dimensions!
                          As I mentioned. try home 1 axis at a time, please. then we can tweak homeall
                            TheBasedDoge
                            Ok for individual homes:
                            Homex - works fine
                            Homey - error, insufficient axis homed
                            homez - error, needs to home y.
                            • PaulHewundefined
                              PaulHew
                              without you finger on x and Y? 🙂
                              • PaulHewundefined
                                PaulHew
                                My X and Y endstops
                                ;Endstop Configuration
                                • PaulHewundefined
                                  PaulHew
                                  if the endstops are not engaged what does it say in
                                  Machine specific - Endstops? in DWC
                                    TheBasedDoge
                                    Yeah, that is without my finger on any endstops.
                                    But just to see what would happen, i did this.
                                    Changed:
                                    To:
                                    G1 H1 Y-305 ; home Y axis
                                    G1 H1 Y-305 ; then move slowly to Y axis endstop
                                    now it's working! I changed it in homey also.
                                    oh its working in machine specific - endstop also... it changes correctly based on the trigger
                                      TheBasedDoge
                                      Well, another problem of course. The fans are not working:
                                      New fan code:
                                      M950 F0 C"Part" Q500 ; create fan 0 on pin fan0 and set its frequency
                                      old 2.x fan code which worked
                                      • PaulHewundefined
                                        PaulHew
                                        my fans for comparison
                                        M950 F0 C"fan0"						;Part Cooling Fan
                                        M106 P0 H-1
                                        M950 F1 C"fan1" Q500                           ;Hotend Fan
                                        M106 P1 S1 H1 T40
                                        M950 F2 C"fan2"						;_RRF3_ define fan2
                                        M106 P2 H-1
                                          TheBasedDoge
                                          That worked for part fan, hotend fan is still not working for some reason. I also have dual extrusion. The only change i made was adding H1:2
                                          M106 P0 H-1
                                          M106 P1 S1 H1:2 T40
                                          EDIT: ah nevermind, im dumb. I had the fan plugged into the fan2 the entire time
                                            TheBasedDoge
                                            Ok, I am making progress on getting everything working, still a few issues.
                                            Does anyone know how I can tell the duet to home X, hit the endstop, move over 15mm and tell that to be the X home position? reason being, my endstop for X is actually too far off the bed.
                                            deckingmanundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
