    Many issues after upgrading to 3.0 RC-12
    Firmware installation
    1.8k
    • PaulHewundefined
      PaulHew
      Just incase your axis is over the other side of the bed, it needs to know how far it can go. It is only a homing move, not bed dimensions!
      As I mentioned. try home 1 axis at a time, please. then we can tweak homeall
      • TheBasedDogeundefined
        TheBasedDoge
        Ok for individual homes:
        Homex - works fine
        Homey - error, insufficient axis homed
        homez - error, needs to home y.
        • PaulHewundefined
          PaulHew
          without you finger on x and Y? 🙂
          • PaulHewundefined
            PaulHew
            My X and Y endstops
            ;Endstop Configuration
            M574 X1 S1 P"xstop"			             ; _RRF3
            M574 Y1 S1 P"ystop"			             ; _RRF3
            • PaulHewundefined
              PaulHew
              if the endstops are not engaged what does it say in
              Machine specific - Endstops? in DWC
                TheBasedDoge
                Yeah, that is without my finger on any endstops.
                But just to see what would happen, i did this.
                Changed:
                G1 H1 Y-5 ; home Y axis
                G1 H1 X-305 F300 ; move slowly to X axis endstop once more (second pass)
                G1 H1 Y-5 ; then move slowly to Y axis endstop
                To:
                G1 H1 Y-305 ; home Y axis
                G1 H1 Y-305 ; then move slowly to Y axis endstop
                now it's working! I changed it in homey also.
                oh its working in machine specific - endstop also... it changes correctly based on the trigger
                  TheBasedDoge
                  Well, another problem of course. The fans are not working:
                  New fan code:
                  M950 F0 C"Part" Q500 ; create fan 0 on pin fan0 and set its frequency
                  M950 F1 C"Hotend" Q500 ; create fan 1 on pin fan1 and set its frequency
                  M106 P1 S1 H1:2 T100 ; set fan 1 value. Thermostatic control is turned on
                  old 2.x fan code which worked
                  M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P2 S1 I0 F500 H1:2 T100 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  • PaulHewundefined
                    PaulHew
                    my fans for comparison
                    M950 F0 C"fan0"						;Part Cooling Fan
                    M106 P0 H-1
                    M950 F1 C"fan1" Q500                           ;Hotend Fan
                    M106 P1 S1 H1 T40
                    M950 F2 C"fan2"						;_RRF3_ define fan2
                    M106 P2 H-1
                      TheBasedDoge
                      That worked for part fan, hotend fan is still not working for some reason. I also have dual extrusion. The only change i made was adding H1:2
                      M106 P0 H-1
                      M106 P1 S1 H1:2 T40
                      EDIT: ah nevermind, im dumb. I had the fan plugged into the fan2 the entire time
                        TheBasedDoge
                        Ok, I am making progress on getting everything working, still a few issues.
                        Does anyone know how I can tell the duet to home X, hit the endstop, move over 15mm and tell that to be the X home position? reason being, my endstop for X is actually too far off the bed.
                        deckingmanundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                          deckingman @TheBasedDoge
                          @TheBasedDoge said in Many issues after upgrading to 3.0 RC-12:
                          https://duet3d.dozuki.com/Wiki/Gcode#Section_G92_Set_Position. So home X, move it 15mm, then use G92 X0.
                            Phaedrux Moderator @TheBasedDoge
                            You can also use a negative value for your M208 X minima such that 0 is the edge of the bed and the negative value is when the endstop is triggered.
                              TheBasedDoge
                              @deckingman said in Many issues after upgrading to 3.0 RC-12:
                              G92 X0
                              Ok, this did the trick perfectly, now the nozzle is lined up with the corner of the bed. Thank you!
                              Next issue..... When I run my G29 it skips the back half of the bed entirely. I suspect I have something set wrong with the offsets or mesh config but I must not be understanding the math correctly
                              G29
                              Warning: Skipping grid point (20.0, 215.0) because Z probe cannot reach it
                              Warning: Skipping grid point (70.0, 215.0) because Z probe cannot reach it
                              Warning: Skipping grid point (120.0, 215.0) because Z probe cannot reach it
                              Warning: Skipping grid point (170.0, 215.0) because Z probe cannot reach it
                              Warning: Skipping grid point (220.0, 215.0) because Z probe cannot reach it
                              Warning: Skipping grid point (270.0, 215.0) because Z probe cannot reach it
                              Warning: Skipping grid point (270.0, 265.0) because Z probe cannot reach it
                              Warning: Skipping grid point (220.0, 265.0) because Z probe cannot reach it
                              Warning: Skipping grid point (170.0, 265.0) because Z probe cannot reach it
                              Warning: Skipping grid point (120.0, 265.0) because Z probe cannot reach it
                              Warning: Skipping grid point (70.0, 265.0) because Z probe cannot reach it
                              Warning: Skipping grid point (20.0, 265.0) because Z probe cannot reach it
                              24 points probed, min error -0.018, max error 1.523, mean 0.769, deviation 0.410
                              Height map saved to file 0:/sys/heightmap.csv
                              Here are my definitions for Z probe offsets and mesh
                              M950 S0 C"exp.heater7"                                 ; create servo pin 0 for BLTouch
                              M558 P9 C"^zprobe.in" H5 F120 T6000   A5 S0.02       ; set Z probe type to bltouch and the dive height
                              G31 P500 X20 Y5 Z2                                   ; set Z probe trigger value, offset and trigger height
                              M557 X20:290 Y15:290 S50                               ; define mesh grid
                              My bed is a 300x300. I set it to 290x290 to allow for room for it to not hit the bed clips
                                Make sure your probe offset is correct. -X to the left, +X to the right. -Y to the front, +Y to the back.
                                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
                                  TheBasedDoge
                                  Ah ok, that was wrong. my probe is front right of the primary nozzle, so i changed it now to read y-5
                                  Still having the same issue, back third of the bed will not probe
                                  G29
                                    Please post your whole config.g file as it is now.
                                      TheBasedDoge
                                      Ok, here it is. thank you!
                                      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 10 2020 13:55:08 GMT-0400 (Eastern Daylight Time)
                                      G90                                                    ; send absolute coordinates...
                                      M83                                                    ; ...but relative extruder moves
                                      M550 P"Hypercube"                                      ; set printer name
                                      M667 S1                                                ; select CoreXY mode
                                      M552 S1                                                ; enable network
                                      M586 P0 S1                                             ; enable HTTP
                                      M586 P1 S0                                             ; disable FTP
                                      M586 P2 S0                                             ; disable Telnet
                                      M569 P0 S1                                             ; physical drive 0 goes forwards
                                      M569 P1 S1                                             ; physical drive 1 goes forwards
                                      M569 P2 S1                                             ; physical drive 2 goes forwards
                                      M569 P3 S1                                             ; physical drive 3 goes forwards
                                      M569 P4 S1                                             ; physical drive 4 goes forwards
                                      M584 X0 Y1 Z2 E3:4                                     ; set drive mapping
                                      M350 X16 Y16 Z16 E16:16 I1                             ; configure microstepping with interpolation
                                      M92 X80.00 Y80.00 Z400.00 E86.00:86.00                 ; set steps per mm
                                      M566 X900.00 Y900.00 Z12.00 E120.00:120.00             ; set maximum instantaneous speed changes (mm/min)
                                      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00        ; set maximum speeds (mm/min)
                                      M201 X5000.00 Y5000.00 Z20.00 E250.00:250.00             ; set accelerations (mm/s^2)
                                      M906 X800 Y800 Z800 E800:800 I30                       ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30                                                ; Set idle timeout
                                      M208 X0 Y0 Z0 S1                                       ; set axis minima
                                      M208 X300 Y0 Z0 S0                                     ; set axis maxima
                                      M574 X1 S1 P"!xstop"                                    ; configure active-low endstop for low end on X via pin xstop
                                      M574 Y1 S1 P"!ystop"                                    ; configure active-low endstop for low end on Y via pin ystop
                                      M574 Z1 S2                                              ; configure Z-probe endstop for low end on Z
                                      G31 P500 X20 Y-5 Z3.7                                   ; set Z probe trigger value, offset and trigger height
                                      M557 X20:290 Y0:290 S50                               ; define mesh grid
                                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138         ; configure sensor 0 as thermistor on pin bedtemp
                                      M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
                                      M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
                                      M307 H0 B1 S1.00                                       ; enable bang-bang mode for the bed heater and set PWM limit
                                      M140 H0                                                ; map heated bed to heater 0
                                      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                                      M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
                                      M143 H1 S280                                           ; set temperature limit for heater 1 to 280C
                                      M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
                                      M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp
                                      M950 H2 C"e1heat" T2                                   ; create nozzle heater output on e1heat and map it to sensor 2
                                      M143 H2 S280                                           ; set temperature limit for heater 2 to 280C
                                      M307 H2 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
                                      M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
                                      M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
                                      M950 F2 C"fan2"					       ; Board cooling fan
                                      M106 P2 S80 H-1
                                      M563 P0 S"Right Nozzle" D0 H1 F0                       ; define tool 0
                                      G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
                                      G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
                                      M563 P1 S"Left Nozzle" D1 H2 F0                        ; define tool 1
                                      G10 P1 X0 Y0 Z0                                        ; set tool 1 axis offsets
                                      G10 P1 R0 S0                                           ; set initial tool 1 active and standby temperatures to 0C
                                      ; Custom settings
                                      M575 P1 B57600 S1                                      ;paneldue settings to enable connection
                                      M564 H0                                                ;allow movement before homing
                                      M501 						       ;load config overrides
                                      sebkritikelundefined 1 Reply Last reply Reply Quote 0
                                      • sebkritikelundefined
                                        sebkritikel @TheBasedDoge
                                        That looks like a mistake - Y300 right??
                                        Large(ish?) IDEX - 6HC, 1HCL
                                        Stratasys Dimension 1200es to 6HC Conversion
                                        TheBasedDogeundefined 1 Reply Last reply Reply Quote 3
                                          TheBasedDoge @sebkritikel
                                          @sebkritikel
                                          Yeah that seems to have been it. I was using the RR config tool and I don't think it filled in any of this stuff correctly. I set my maxima for XYZ now correctly and ran the probing again and it seems to have worked.
                                          One more thing - on my RR 2 FW the BLTouch only probed each spot 1 time, now it does it like 4 times. Is this a setting somewhere?
                                          Also wondering on the correct way to do start Gcode with mesh enabled. I have this:
                                          G29 S1 ;Load heatmap
                                          G28
                                          G1 Z15.0 F7000 ;Move the platform down 15mm
                                          G92 E0
                                          G1 F200 E3
                                          G92 E0
                                          G1 X150 Y150 F7000 ; Move Probe to middle of bed
                                          G30 ; Do a single probe
                                          Should I change anything?
                                          dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                            dc42 administrators @TheBasedDoge
                                            Yes, see the documentation for M558.
