    Many issues after upgrading to 3.0 RC-12
    Firmware installation
    1.8k
    • deckingmanundefined
      deckingman @TheBasedDoge
      @TheBasedDoge said in Many issues after upgrading to 3.0 RC-12:
      Does anyone know how I can tell the duet to home X, hit the endstop, move over 15mm and tell that to be the X home position? reason being, my endstop for X is actually too far off the bed.
      https://duet3d.dozuki.com/Wiki/Gcode#Section_G92_Set_Position. So home X, move it 15mm, then use G92 X0.
        Phaedrux Moderator @TheBasedDoge
        You can also use a negative value for your M208 X minima such that 0 is the edge of the bed and the negative value is when the endstop is triggered.
        • TheBasedDogeundefined
          TheBasedDoge
          @deckingman said in Many issues after upgrading to 3.0 RC-12:
          G92 X0
          Ok, this did the trick perfectly, now the nozzle is lined up with the corner of the bed. Thank you!
          Next issue..... When I run my G29 it skips the back half of the bed entirely. I suspect I have something set wrong with the offsets or mesh config but I must not be understanding the math correctly
          G29
          Warning: Skipping grid point (20.0, 215.0) because Z probe cannot reach it
          Warning: Skipping grid point (70.0, 215.0) because Z probe cannot reach it
          Warning: Skipping grid point (120.0, 215.0) because Z probe cannot reach it
          Warning: Skipping grid point (170.0, 215.0) because Z probe cannot reach it
          Warning: Skipping grid point (220.0, 215.0) because Z probe cannot reach it
          Warning: Skipping grid point (270.0, 215.0) because Z probe cannot reach it
          Warning: Skipping grid point (270.0, 265.0) because Z probe cannot reach it
          Warning: Skipping grid point (220.0, 265.0) because Z probe cannot reach it
          Warning: Skipping grid point (170.0, 265.0) because Z probe cannot reach it
          Warning: Skipping grid point (120.0, 265.0) because Z probe cannot reach it
          Warning: Skipping grid point (70.0, 265.0) because Z probe cannot reach it
          Warning: Skipping grid point (20.0, 265.0) because Z probe cannot reach it
          24 points probed, min error -0.018, max error 1.523, mean 0.769, deviation 0.410
          Height map saved to file 0:/sys/heightmap.csv
          Here are my definitions for Z probe offsets and mesh
          M950 S0 C"exp.heater7"                                 ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F120 T6000   A5 S0.02       ; set Z probe type to bltouch and the dive height
          G31 P500 X20 Y5 Z2                                   ; set Z probe trigger value, offset and trigger height
          M557 X20:290 Y15:290 S50                               ; define mesh grid
          My bed is a 300x300. I set it to 290x290 to allow for room for it to not hit the bed clips
            Make sure your probe offset is correct. -X to the left, +X to the right. -Y to the front, +Y to the back.
            https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
              TheBasedDoge
              Ah ok, that was wrong. my probe is front right of the primary nozzle, so i changed it now to read y-5
              Still having the same issue, back third of the bed will not probe
              G29
                Please post your whole config.g file as it is now.
                  TheBasedDoge
                  Ok, here it is. thank you!
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 10 2020 13:55:08 GMT-0400 (Eastern Daylight Time)
                  G90                                                    ; send absolute coordinates...
                  M83                                                    ; ...but relative extruder moves
                  M550 P"Hypercube"                                      ; set printer name
                  M667 S1                                                ; select CoreXY mode
                  M552 S1                                                ; enable network
                  M586 P0 S1                                             ; enable HTTP
                  M586 P1 S0                                             ; disable FTP
                  M586 P2 S0                                             ; disable Telnet
                  M569 P0 S1                                             ; physical drive 0 goes forwards
                  M569 P1 S1                                             ; physical drive 1 goes forwards
                  M569 P2 S1                                             ; physical drive 2 goes forwards
                  M569 P3 S1                                             ; physical drive 3 goes forwards
                  M569 P4 S1                                             ; physical drive 4 goes forwards
                  M584 X0 Y1 Z2 E3:4                                     ; set drive mapping
                  M350 X16 Y16 Z16 E16:16 I1                             ; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z400.00 E86.00:86.00                 ; set steps per mm
                  M566 X900.00 Y900.00 Z12.00 E120.00:120.00             ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00        ; set maximum speeds (mm/min)
                  M201 X5000.00 Y5000.00 Z20.00 E250.00:250.00             ; set accelerations (mm/s^2)
                  M906 X800 Y800 Z800 E800:800 I30                       ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                                ; Set idle timeout
                  M208 X0 Y0 Z0 S1                                       ; set axis minima
                  M208 X300 Y0 Z0 S0                                     ; set axis maxima
                  M574 X1 S1 P"!xstop"                                    ; configure active-low endstop for low end on X via pin xstop
                  M574 Y1 S1 P"!ystop"                                    ; configure active-low endstop for low end on Y via pin ystop
                  M574 Z1 S2                                              ; configure Z-probe endstop for low end on Z
                  G31 P500 X20 Y-5 Z3.7                                   ; set Z probe trigger value, offset and trigger height
                  M557 X20:290 Y0:290 S50                               ; define mesh grid
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4138         ; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
                  M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
                  M307 H0 B1 S1.00                                       ; enable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                                ; map heated bed to heater 0
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                  M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
                  M143 H1 S280                                           ; set temperature limit for heater 1 to 280C
                  M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
                  M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp
                  M950 H2 C"e1heat" T2                                   ; create nozzle heater output on e1heat and map it to sensor 2
                  M143 H2 S280                                           ; set temperature limit for heater 2 to 280C
                  M307 H2 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
                  M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
                  M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
                  M106 P1 S1 H1:2 T100                                   ; set fan 1 value. Thermostatic control is turned on
                  M950 F2 C"fan2"					       ; Board cooling fan
                  M106 P2 S80 H-1
                  M563 P0 S"Right Nozzle" D0 H1 F0                       ; define tool 0
                  G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
                  G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
                  M563 P1 S"Left Nozzle" D1 H2 F0                        ; define tool 1
                  G10 P1 X0 Y0 Z0                                        ; set tool 1 axis offsets
                  G10 P1 R0 S0                                           ; set initial tool 1 active and standby temperatures to 0C
                  ; Custom settings
                  M575 P1 B57600 S1                                      ;paneldue settings to enable connection
                  M564 H0                                                ;allow movement before homing
                  M501 						       ;load config overrides
                  sebkritikelundefined 1 Reply Last reply Reply Quote 0
                  • sebkritikelundefined
                    sebkritikel @TheBasedDoge
                    That looks like a mistake - Y300 right??
                    Large(ish?) IDEX - 6HC, 1HCL
                    Stratasys Dimension 1200es to 6HC Conversion
                    TheBasedDogeundefined 1 Reply Last reply Reply Quote 3
                      TheBasedDoge @sebkritikel
                      @sebkritikel
                      Yeah that seems to have been it. I was using the RR config tool and I don't think it filled in any of this stuff correctly. I set my maxima for XYZ now correctly and ran the probing again and it seems to have worked.
                      One more thing - on my RR 2 FW the BLTouch only probed each spot 1 time, now it does it like 4 times. Is this a setting somewhere?
                      Also wondering on the correct way to do start Gcode with mesh enabled. I have this:
                      G29 S1 ;Load heatmap
                      G28
                      G1 Z15.0 F7000 ;Move the platform down 15mm
                      G92 E0
                      G1 F200 E3
                      G92 E0
                      G1 X150 Y150 F7000 ; Move Probe to middle of bed
                      G30 ; Do a single probe
                      Should I change anything?
                      dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        dc42 administrators @TheBasedDoge
                        Yes, see the documentation for M558.
                          TheBasedDoge
                          Got it - I just noticed this error after starting a print
                          Warning: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset.
                          I am watching the Z motor and it seems to be adjusting as the head moves around though.
                            https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Establish_a_Z_0_datum_using_the_Z_probe
                              TheBasedDoge
                              So I read this and I am still a little confused why it's happening - because I did this:
                              "Move the nozzle over the centre of the bed and do a single G30 probe (G30 without parameters)."
                              The center of bed G30 is in my start gcode for each print.
                              The only difference that I did not do is run the G29 while the printer was hot. Is this the reason the error is coming up?
        G29 S1 ;Load heatmap        G28        G1 Z15.0 F7000 ;Move the platform down 15mm        G92 E0        G1 F200 E3        G92 E0        G1 X150 Y150 F7000 ; Move Probe to middle of bed        G30 ; Do a single probe
                                You've loaded the heightmap before you've done the G30. That's the problem.
