Print dimension off
  • Hi,
    I have printed a piece.... a small piece.... but print off of dimension
    Dimension of STL, its like a cilinder
    X = 51.16 mm
    Y = 51.16 mm
    Z = 15 mm
    Printed dimension
    X = 57.2 mm (off of dimension)
    Y = 51.6 mm ( Its ok for me)
    Z = 15.3 mm (its ok for me)
    Layers seems ok.
    The overall finish its ok
    Slicer Cura 4.6
    Printer: Delta with linear rails
    Don't seems a mechannical issue.... not sure
    Ideas what i have to check?
  • Hi, I also had this problem with my delta printer and I also was in trouble because of the mismatch of the dimensions of the print.
    But, looking around, I found and followed this https://duet3d.dozuki.com/Wiki/Gcode#Section_M579_Scale_Cartesian_axes
    Everything now is correct.
  • Solved, i have try with another slicer and works OK... suppose.when I have added stl to.Cura, a haves scaled in one axis...
    Sorry for disturb
    @Sytac072. ... time ago I have try ti use these gcode in my Delta. ... and no works as spected. ..Delta kninematics are particular, and all axes have relationship. ..
