    z probe wont respond to G31
    1.1k
    • ziggymanpopoundefined
      ziggymanpopo
      Is G 31 the place i need to set my off
      set?? Im not sure at all
        Do you have a G31 in your homing files or beg.g?
          ziggymanpopo
          No more entries in any other files that i know of.
            1. Is it the height after homing Z that isn't changing? If so then that may indicate an error in your homeall.g and/or homez.g files.
            2. What Duet and firmware version are you using?
              ziggymanpopo
              i believe the corect anser to be ver1.12
              also remeber ihad to reload my www. file
              so ver1.12. with the v2 dwc interface. would that be correct?
              heres the config g < home all< and the home z files for you to see
              ( ill remove G29 S1 )
              ; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time)
              M550 Pe3 ; Set machine name
              M552 S1 ; Enable network
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M569 P0 S0 ; Drive 0 goes forward
              M569 P3 S1 ; Drive 3 (Extruder 0) goes backwards
              ; M92 X79.7 Y320 Z400.4 E96 ; Set steps per mm
              M92 X79.2 Y320 Z400.5 E96 ; Set steps per mm
              M566 X1600 Y500 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
              M203 X30000 Y1600 Z300 E1500 ; Set maximum speeds (mm/min)
              M201 X500 Y500 Z300 E5000 ; Set accelerations (mm/s^2) is 500
              M906 x950 Y1200 Z850 E950 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S300 ; Set idle timeout
              ; M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
              ; M208 X495 Y495 Z460 S0 ; Set axis maxima
              M208 X500 Y500 Z500 S0 ; Set axis maxima
              M574 X1 Y1 Z1 S1 ; Set endstops controlled by sw. x controlled by capasitive sensor
              ; M558 P5 H5 F100 T2000 ; Set Z probe type to capasitive and the dive height + speeds
              M558 P5 H5 F100 T4000 ; Set Z probe type to capasitive and the dive height + speeds
              G31 P500 X-42 Y-5 Z7.75 ; Set Z probe trigger value, offset and trigger height - is Nozzle higer
              M557 X15:215 Y35:215 S20 ; Define mesh grid
              M143 H0 S120 ; Set temperature limit for heater 0 to 80C
              M305 P1 T100000 B4400 R4700 ; Set thermistor + ADC parameters for heater 1
              M143 H1 S280 ; Set temperature limit for heater 1 to 240C
              ; M307 H1 A245.3, C121.7, D4.0, S0.5 ; PID
              ; M106 P0 S1 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
              ; M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
              home all; Tools
              M563 P0 D0 H1 ; Define tool 0
              ; Enable Bed Leveling
              G29 S1 ; Enable Mesh Bed Leveling
              Home All
              G91 ; relitave mode
              G1 S2 Z4 F3000 ; raize head 4mm
              G1 S1 X-500 Y-600 f3000 ; move y and x to endstops in -neg direction until end sw trip
              G1 S2 X4 Y4 f600 ; move slowly 6mm in + direction
              G1 S1 X-10 Y-10 ; move up to 10mm in the Y- andX- directions untill the homming switches are trigered
              G90 ; back to absolute mode
              G1 X125 Y125 F3000 ; put head at fist probe piont
              G30 ; lower head , stop when z probe is trigered
              home z
              ; homez.g
              ; called to home the Z axis
              G91 ; relative positioning
              G1 Z2.5 F6000 S2 ; lift Z relative to current position
              G90 ; absolute positioning
              G1 X51 Y20 F6000 ; go to first probe point
              ;G91 ; relative positioning
              ;G1 S2 Z2.5 F100 ; lift Z relative to current position
              ;G90 ; absolute positioning
                ziggymanpopo
                also just found this file called bed g.
                G29 ; probe the bed and enable compensation
                not sure, but is this for slicer start code??
                  ziggymanpopo
                  will this also add another error for z offset or ??? is this one o k in its separate system fie
                    ziggymanpopo
                    lets start over new thread
                    re ask the question
                    this is where im at
                    duet reports z at 12.75 after homeing
                    trigger height is at 7.75
                    zerro is at is at 6.30
                    during a print the duet throws back the Z tool position as 1.42 with the nozzle burried in the glass
                    in my mind all Entries are a positive #
                    Z-Probe
                    G31 P500 X-42 Y-5 Z7.75 ; Set Z probe trigger value, offset and trigger height - is Nozzle hoger
                      ziggymanpopo
                      is this my error ...Z7.75 should it read Z-7.75 is it a flipin - that been hanging Me???
                      • aidarundefined
                        aidar
                        I dont know if it is related to your problem or not, but you should remove G29 S1 from config.g. You can not enable mesh compensation before homing. G29 should come after homing, not before.
                          ziggymanpopo
                          i believe its commented out wouldn't that do the same
                          • aidarundefined
                            aidar
                            @ziggymanpopo said in z probe wont respond to G31:
                            Does not seems to be commented out.
                              ziggymanpopo
                              ;G29 S1
                                ziggymanpopo
                                think i did it right after im just stumped?? are my settings right ??
                                  ziggymanpopo
                                  other than that ??
                                    ziggymanpopo
                                    offset suppose to be a neg. # instead of pos #...maybe????
                                    • aidarundefined
                                      aidar
                                      Only thing i recommend is, for me changing Z offset works if i change it in config.g G31 command and restart printer. I know it should work "on the fly", but for some reason sometimes doesnt work for me.
                                      • aidarundefined
                                        aidar
                                        And no, offset should be positive, until your probe is not your nozzle like smart effector or piezo something...
                                          ziggymanpopo
                                          so note no neg for Z
                                            ziggymanpopo
                                            ???? not sure the instructions said pos triger hieght all other sensors other than toutch nozzel ???
