Printer Pausing Near End of Print
  • Hello. I recently just converted my Anet A8 motherboard to a duet wifi board. Once I set up the board, I followed my calibration process (PID tunes, extrusion calibration) and printed a test cube. However, near the end of the print (about 98% completion) my just printer stops on top of the print with the heaters off. The printer still says it is printing, its just not doing anything. I though it was the firmware so I upgraded it to RRF3. Same issue. Here is my g-code:
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat May 16 2020 14:23:01 GMT-0500 (Central Daylight Time)
    M550 P"Tom" ; set printer name
    M575 P1 B57600 S1 ;Set baud rate Duet Board.
    M575 P0 B57600 S1 ;Set baud rate USB
    M551 P"" ; set password
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M92 X100.00 Y100.00 Z400.00 E414.44 ; set steps per mm
    M566 X600.00 Y600.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
    M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
    M906 X500 Y500 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-30 Y-8 Z0 S1 ; set axis minima
    M208 X220 Y220 Z240 S0 ; set axis maxima
    M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop
    M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop
    M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
    M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
    M557 X20:200 Y20:200 S40 ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
    M143 H0 S130 ; set temperature limit for heater 0 to 130C
    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
    M950 F1 C"fan1" Q100 ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S70 H-1 ; set fan 1 value. Thermostatic control is turned off
    M950 F2 C"fan2" Q50 ; create fan 2 on pin fan2 and set its frequency
    M106 P2 S150 H-1 ; set fan 2 value. Thermostatic contol is turned off
    T0 ; select first tool
    M501
    Here is what the M122 command shows when the problem occurs:
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0 running on Duet WiFi 1.02 or later
    Board ID: 08DLM-996RU-N8PS0-7JTDG-3SN6S-TVB7Q
    Used output buffers: 3 of 24 (22 max)
    Static ram: 28180
    Dynamic ram: 93540 of which 20 recycled
    Exception stack ram used: 568
    Never used ram: 8764
    Tasks: NETWORK(ready,100) HEAT(blocked,1216) MAIN(running,1880) IDLE(ready,80)
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:13:52 ago, cause: power up
    Last software reset at 2020-05-18 16:55, reason: User, spinning module GCodes, available RAM 8956 bytes (slot 1)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 26.6, current 27.0, max 27.3
    Supply voltage: min 11.7, current 12.9, max 13.0, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 3: ok, SG min/max 0/350
    Date/time: 2020-05-18 19:12:37
    Cache data hit count 1395047326
    Slowest loop: 8.94ms; fastest: 0.12ms
    === Storage ===
    Free file entries: 9
    SD card longest read time 3.6ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 168, MinFreeDm: 150, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 3638, completed moves: 3636, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
    === AuxDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    Heater 0 is on, I-accum = 0.5
    Heater 1 is on, I-accum = 0.3
    Segments left: 0
    Movement lock held by File
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is doing "G28 X0 Y0 " in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 201.13ms; fastest: 0.09ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is active
      Failed messages: pending 0, notready 0, noresp 1
      WiFi firmware version 1.23
      WiFi MAC address bc:dd:c2:2d:68:c1
      WiFi Vcc 3.44, reset reason Unknown
      WiFi flash size 4194304, free heap 24008
      WiFi IP address
      WiFi signal strength -62dBm, reconnections 0, sleep mode modem
  • Moderator
    So it stops at exactly the same point in the gcode file?
    Can you post that gcode file please?
  • It's an issue with 3.1.0. Please update to 3.1.1
  • Moderator
    @Tommygunz said in Printer Pausing Near End of Print:
    @jay_s_uk though this makes it sound like he was on RRF2 previously when the issue happened.
  • @Phaedrux sorry, missed that bit.
  • It was the software. Updated it to 3.1.1 and the problem went away!
